Trans swap
Old Sep 4, 2016 | 06:31 PM
blkmax1's Avatar
Trans swap
Me and a buddy of mine found a 01Ae for parts... How long will it take to pull the trans? I know it has a lsd trans which is better than an open diff. We are on a time schedule so how can this be done efficiently?
Old Sep 5, 2016 | 01:47 PM
sebastian2041's Avatar
I know the vq35 took me less than an hour to take it out
Old Sep 11, 2016 | 11:20 AM
blkmax1's Avatar
Okay got everything swapped but I want to put fresh fluid in it because the old fluid is real dark! What the proper and best fluid to use?
Old Sep 11, 2016 | 12:43 PM
redline with w.e weight the manual ask
For
Old Sep 11, 2016 | 04:16 PM
blkmax1's Avatar
Okay I've read and heard that valvoline multi import is good. I want the best fluid I can get and I will be draining again within 3000 miles. Trans has 180k, shifts good but the fluid was horrible
Old Sep 12, 2016 | 07:41 AM
Reallyslowrio's Avatar
I bought trans fluid for mine at Nissan. It was very reasonable, considering GL4 is getting harder and harder to come by.
Old Sep 12, 2016 | 09:58 AM
MaximaNoob1's Avatar
Don't want to make a second thread on the topic, but I'm considering swapping transmissions as I don't want to spend $400 on a new solenoid pack when it might even fix the issue. Not gonna do a manual swap or anything, just want to find a low mileage 4AT that I can get for cheap. My car has been in the rust belt (Wisconsin) its whole life, so is there anything that will need more attention? Thanks.
Old Sep 20, 2016 | 10:15 PM
BronxSleeperMax187's Avatar
You don't need to spend that much on solenoid packs.....but ur right it might not fix the problem anyway.....save for rebuild bro and do it right IMO,while they are at it might wanna add some goodies too like A cooler and valve body mod.... good luck
Old Sep 21, 2016 | 07:53 AM
Derrick2k2SE's Avatar
I wouldn't put GL4 in an auto.
If you really want an upgrade in your 6-speed then ditch the Nissan fluid for some Redline MT90. I refilled mine with Nissan fluid in a pinch and noticed a real loss in shifting smoothness. As soon as I went back to the MT90 it started shifting smoothly again.
Old Sep 21, 2016 | 10:37 AM
I guess we should have figured out whether OP has a manual or auto first...
Old Sep 21, 2016 | 11:22 AM
LOL, I only knew because he said he was considering Valvoline Multi Import which is ATF.
Old Sep 21, 2016 | 05:23 PM
go to car parts.com and find something locally you can ic up and get some warranty i only took ut my 6 speed but im sure its similar and its something you can do in you parking lot have fun
Pnjboyzz
Nov 10, 2016 08:38 AM
luke95gxe
20
Oct 3, 2016 01:20 PM
pnice74
Aug 30, 2016 10:02 AM
darkdream
Aug 28, 2016 06:07 PM
Hulksmash117
Aug 21, 2016 05:50 PM
