No brake lights stuck in park /5th gen Maxima
Old Feb 6, 2017 | 04:44 PM
Tufhchc's Avatar
Okay so have a 5th gen Maxima with 179k on it I have had this problem before with the brake light switch not working and it will not release the shift lock solenoid out of park..Today I have looked at everything I could think of brake light switch ,fuse under dash board for stop lamp, and the shift interlock solenoid,fuses under the hood..both he stop lamp switch has been replaced and so has the shift interlock solenoid..suggestions anyone? Need help !
Old Aug 16, 2017 | 03:36 PM
Derrick2k2SE's Avatar
Did you check the actual switch at the pedal arm?
Old Aug 16, 2017 | 03:59 PM
SubwayVQ's Avatar
Changing the brake lights will not fix your issue, the bulb has nothing to do with the operation of the brake pedal. My guess would be the actual switch on the pedal. If that does not fix it, you might need to do some electrical diagnosis. See if the switch is getting power, and then find the wire that runs along the car and test in various spots for the same signal. Once you find it has no signal, work backwards to find the broken wire.
Old Aug 16, 2017 | 04:41 PM
Doc Plus's Avatar
Please come on the original topic = 6th gen = https://maxima.org/forums/6th-genera...ft-locked.html
It will avoid us to repeat the same thing.
Old Aug 17, 2017 | 08:47 AM
I think the solenoid is right there by the shifter near where your knee would rest.
If you pull the console you can access the solenoid and bypass it to at least get the car moving.
Old Aug 17, 2017 | 09:08 AM
Doc Plus's Avatar
All the messages posted yesterday were replying to a guy who has erased (or the admin did) all his messages ...
Old Aug 20, 2017 | 06:18 PM
FanaticMadMax's Avatar
Possibly the Neutral safety switch. Need more info
Old Apr 3, 2019 | 03:42 PM
Swbrown's Avatar
06 Maxima Shifter Stuck Brake Lights Won’t Come On
Is my brake stopper missing? Noticed brake lights not working when I’m town today. Shifter also stuck. I had my brake shifter replaced. Brake lights worked but shifter still stuck. Next stop I noticed brake lights not coming on again. I cannot tell if the stopper missing by reading the thread and looking at the photos. I’m adding photos of mine w/brake pedal pressed and not pressed. Thank you all so much!
Old Apr 4, 2019 | 07:02 AM
LA02MAX's Avatar
Yes, all you need is that little plastic stopper that plugs into the hole on the metal arm. The same thing has happened in the last year on my maxima with both the clutch and brake pedals, so I bought like 8 of those stoppers for the future. They're very cheap from Nissan. In the interim, you can fold duct tape over into a square a bunch of times until it's thick enough then tape that square the arm so it pushes on the switch.
Old Apr 4, 2019 | 02:59 PM
DennisMik's Avatar
If the plastic stopper on the brake pedal falls out, the brake lights will be on all the time. The brake lights not lighting up is something else, possibly a bad fuse.
Check out this link. Scroll down to post # 8 for photos.
http://forums.maxima.org/5th-generat...ht-switch.html
smackdown85
35
Aug 21, 2023 10:05 PM
Tufhchc
Feb 8, 2017 08:51 AM
auveeb
May 18, 2011 06:11 PM
auveeb
May 14, 2011 11:19 PM
