Front Passenger CV Shaft (Axle) Replacement
Old Oct 14, 2019 | 04:25 PM
  #41
User1's Avatar
You can put the tranny in whatever gear you like and floor the gas pedal while you are stepping on the brakes. It won't hurt anything.
Please make a video of you doing that and upload it to youtube.
Old Oct 14, 2019 | 05:42 PM
  #42
MichMaxFan's Avatar
Ok. Revved to the 1500 range and see very noticeable movemenf in drive/reverse.
Assuming then that front and rear mounts are bad and my electronic ones have been disconnected.
As I read threads i should buy the manual trans version? If I just buy anchor MT versions 8866 & 9532 then they fit correctly with a clean swap? Not interested in high end bushings or pressing out. Just want to fix it.
Old Oct 14, 2019 | 06:06 PM
  #43
User1's Avatar
I'm automatic, I'm running brand new OEM MT front and rear mounts and I absolutely love them. You will notice a profound difference in off the line acceleration and throttle response with new mounts/. Strong work with your testing. Just goosing it is all you need to make a definitive diagnosis, along with visual inspection. Also, they are easy as cake to replace. You need to spend some time underneath the car. Your brain will start figuring things out once it knows what it's looking at.
Old Oct 16, 2019 | 02:24 AM
  #44
MichMaxFan's Avatar
Ordered the 2 mounts and hope to install this weekend. Will let u know how that goes.
Then I *get* to dig deeper into the y-pipe flex leak.
Yayy. (
Will92
Feb 2, 2016 09:11 AM
followthadollar
Sep 17, 2015 06:31 PM
zero2sixtyZ
Oct 26, 2010 05:46 AM
Kiosk
41
Jun 2, 2005 09:37 PM
1FasMax
Nov 28, 2000 09:11 PM
