headlight replacement
Old Jun 14, 2017 | 05:43 AM
jsmith1's Avatar
hi, i have one headlight/ fog light out. what would be the best route for replacement? aftermarket, oem? thanks
Old Jun 14, 2017 | 05:55 AM
5thgendriver's Avatar
oem...on the headlights but it will be costly. you can get away with aftermarket on the fog lights.
Old Jun 14, 2017 | 06:06 AM
jsmith1's Avatar
some one said for the head light you cant do hids cause you have to do splicing?
Old Jun 14, 2017 | 06:17 AM
TallTom's Avatar
First, what year is the car? And which bulb is out? Headlight and fog light are two different things.
Old Jun 14, 2017 | 06:20 AM
jsmith1's Avatar
03 passenger side for both.
Old Jun 14, 2017 | 06:29 AM
TallTom's Avatar
Car has HID low beam bulbs.
Fog bulb: H3
Low beam: D2R
High beam: 9005
Aftermarket for all three. Sylvania from pepboys for the fog and high beam, and buy the HID online. Replace both sides when doing HID or the headlight colors will be mismatched. I personally do both sides when doing any of the bulbs for if one went out, there is a good chance the other will fail in the near future.
Retrofit source is a good place for replacement HID bulbs:
https://www.theretrofitsource.com/bu...to-xb-hid.html
https://www.theretrofitsource.com/bu...ips-85126.html
Old Jun 14, 2017 | 06:37 AM
jsmith1's Avatar
ok ill order the morimotos, thanks
Old Jun 14, 2017 | 06:38 AM
jsmith1's Avatar
so for the fogs, am i ordering a whole hid kit or just the bulbs?
Old Jun 14, 2017 | 07:12 AM
TallTom's Avatar
Fogs are not HID by default. They are H3 halogen bulbs. You will need a whole kit + creativity if you want to change them to HID.
Old Jun 14, 2017 | 07:17 AM
jsmith1's Avatar
ok thanks for the info, ill just deal with the headlights for now.
Old Aug 27, 2022 | 09:05 AM
Prophecy99's Avatar
Fog bulb: H3
Low beam: D2R
High beam: 9005
thanks for this post TallTom ! and to add to this I think stock kelvin is 4300k
Old Aug 28, 2022 | 06:19 PM
uptownsamcv's Avatar
DDM tuning makes the best HID kits for the money $50 per each 55watt set, I run them on my Maxima low beam and fog and also on my 1000RR. they also have a good lifetime warranty, they have been in business for a long time..
lalo8828
Sep 25, 2018 05:13 PM
Gadgetemt
Oct 10, 2006 03:42 PM
Zipp028
Dec 28, 2004 11:49 PM
zonamax
Mar 29, 2003 01:36 PM
