Coolant leaking at oil pan
Old 06-15-2017, 03:36 PM
maximatech12's Avatar
Flushed cooling system now leak new green coolant behind compressor.
I checked everything and Traced this to an unknown location behind compressor.
I thought refrigerant oil leak from compressor. Ruled that out.
I thought BHG coolant in oil but checked dipstick and level is fine.
After searching the world wide web im thinking water pump seal?
Replace pump or just seal?
maximatech12 is offline
Old 06-15-2017, 04:41 PM
SubwayVQ's Avatar
If you're going to be removing the W/P to replace the seal, just replace the pump with an OE one to avoid future issues.
SubwayVQ is offline
Old 06-15-2017, 05:00 PM
Ok
Old 06-15-2017, 06:12 PM
mclasser's Avatar
Check the oil cooler hose
https://maxima.org/forums/5th-genera...ain-cover.html
mclasser is offline
Old 06-15-2017, 07:01 PM
I'm not seeing an oil cooler here! That may just be the 3.5L.
It leaks to the right behind compressor.
Old 06-15-2017, 08:01 PM
FanaticMadMax's Avatar
The only possible leak aside from Water pump, have you look at the thermostat housing?
FanaticMadMax is offline
Old 06-15-2017, 09:47 PM
DennisMik's Avatar
IIRC, there is a freeze plug in the block behind the a/c compressor that could be leaking.
DennisMik is offline
Old 06-16-2017, 07:06 AM
Tarzan's Avatar
He does not have oil cooler, lucky one.
Fram filter - uh-oh! Never use that crap!
Tarzan is offline
Old 06-16-2017, 08:06 AM
what's wrong with Fram? Never had any problem with it. however I would never use STP filter. I have seen STP filter failed and blew off separating the crimp around the housing.
Old 06-16-2017, 09:05 AM
Tarzan's Avatar
STP, Fram and Champion do not make their own stuff - they scavenge factory seconds and re-label.
Tarzan is offline
Old 06-16-2017, 10:54 AM
Would Purolator would be better?
I can get Nissan filters but I wouldn't think theyd be any better.
Here's a link to a You Tube video and the tech here says he's never seen an OEM pump go bad and the seals only need replacing.
https://youtu.be/ibfs1Zu9h4o
Old 06-23-2017, 01:35 PM
Make a long story short i have a mechanics mirror and the Thermostat housing is bone dry!
Old 06-23-2017, 02:14 PM
Derrick2k2SE's Avatar
Not everyone who calls themselves a "tech" knows what they're talking about.
Derrick2k2SE is offline
Old 06-23-2017, 02:35 PM
SubwayVQ's Avatar
Prime example would be OP himself.
SubwayVQ is offline
Old 06-23-2017, 04:15 PM
Donkeypunch's Avatar
water pump
Donkeypunch is offline
Old 06-26-2017, 04:49 AM
freeze plug? Could you be more specific?
Im seeing a drain plug but not a freeze plug.
You know what size belt to bypass compressor?
Old 06-27-2017, 03:03 PM
OK i removed the compressor and the anti-freeze appears to be leaking from behind the top of the compressor bracket.
I have not removed the alternator yet but is there a freeze plug there?
I was under the impression that this is where the water pump leaks from.
Old 07-06-2017, 10:06 AM
01 Nissan Maxima(coolant leaking)
i did snap an image of the area that has coolant leaking.
Old 07-09-2017, 10:51 AM
is this the freeze plug you were referring to?
This is behind the alternator.
5th gen (coolant leak)
Old 07-09-2017, 01:51 PM
DennisMik's Avatar
That is not what I was thinking of. The freeze plugs I am thinking of are about 1.25 to 1.5 inches in diameter. I don't know what that is. It has been a long time since I looked at a bare block.
Old 07-09-2017, 01:59 PM
Bad *** Newb
Child_uv_KoRn's Avatar
O rings on water pump, I'm sure. Decent amount of work to replace them.
Could rig it lol
Yes, use purolator. PL10193 or PL14459
Child_uv_KoRn is offline
Old 07-10-2017, 09:54 AM
Replace it asap that coolant is getting into your oil and putting extra wear on your engine.
I'm not bullsh!ting. I had the same thing and sent the oil to blackstone and there was a ton more wear going on because of the coolant.
It's been a month since you posted or noticed it. How long has it been like that?
fix it.
Old 07-23-2017, 11:28 AM
It just began after flushing the Prestone out with Distilled water. I was running Prestone(any make/model) through it and replaced with Nissan Green.
I was concerned that the Prestone was corroding the system and not cooling properly. I basically ran water through it for a week or two draining then refilling about 8 times until it came out clear.
If you get Prestone i'd go for the the Prestone "PRIME" low silicate formula!
Old 07-23-2017, 04:34 PM
Replaced today!
01 Nissan Max OEM water pump
Old 07-23-2017, 04:49 PM
fix it.
Would a Cloyes tensioner work OK? I may just go with replacing the chain tensioner too.
Old 07-23-2017, 10:56 PM
idk i didn't replace it.Still worked fine.
Old 08-02-2017, 03:24 AM
i think the pump is fine and the O-rings failed.
I just got a closer look at the old pump and beginning to realize its silicone twisted around the rotary shaft.
I couldve just slipped new O-rings on it and re-installed?
Old 08-02-2017, 06:34 AM
Tarzan's Avatar
How much are you saving doing that and how long do you want to keep the car?
IMO if your pump is 10+ years old and already out of the engine, replace it anyway.
Tarzan is offline
Old 08-30-2017, 08:17 AM
As I did this it ocurred to me that the easiest way to remove the tensioner is to
#1 remove the cover plate
#2 break the two bolts loosen them until they are just about 1/2 dozen threads to coming out
#3 walk the tensioner out using the bolts still screwed in as a guide.
#4 bent the tip of a cheap freebie screwdriver with pliers place folded cardboard along access cover for leverage
#5.Pried the piston in with screwdriver carefully then installing grenade pin.
VQ30 chain tensioner removal
Old 08-30-2017, 09:41 AM
Tarzan's Avatar
Now this is what I call brain surgery!
Tarzan is offline
Old 09-09-2017, 06:18 PM
I was unaware that the tensioner had a gasket behind it!
If I hadnt been careful that thing couldve fallen out into the chain case!
Old 01-16-2019, 06:49 AM
Heres video that details what filters are good and whats not.
thanks for the heads up since I've switched to Purolator.
https://youtu.be/iTNJLEV8CG8
maxinout93
62
11-06-2018 09:32 PM
Double0Max
12-12-2008 10:45 AM
unkadave11
08-05-2006 09:59 PM
Tonyklem
27
04-15-2006 11:25 PM
bthe
02-05-2005 09:01 PM
Quick Reply: Coolant leaking at oil pan
