A-Piller Rattle (not on TSB)
Old Feb 1, 2002 | 03:50 PM
MichaelAE's Avatar
Is anybody experiencing a rattle on the driver's side A-Piller. There is a TSB referring to a squeak in that area due to the A-Piller and console coming into contact. The rattle I am referring to sounds like the VIN plate is rattling around...very metallic, but I confirmed this wasn't the case by holding the VIN plate still while the noise continued to occur. The sound becomes noticeable at around 20mph and increases exponentially at highway speeds.
Anybody? I have reached up and held the air vent, the speaker cover, the console, the plastic cover over the odo/speedo...can't figure out where its coming from.
Old Feb 1, 2002 | 05:59 PM
genix's Avatar
it could be the tweeter?
Old Feb 2, 2002 | 10:38 AM
MichaelAE's Avatar
I thought about that, except the stereo isn't on when I experience this...and if it was the tweeter, why would it increase so dramatically at high speeds?
Old Feb 2, 2002 | 01:16 PM
20 MAXIMA 02's Avatar
speed sensitive volume? or maybe itz one of the clips holding the wires inside ur A pillar that came loose
Old Feb 2, 2002 | 06:17 PM
Loe max's Avatar
Re: A-Piller Rattle (not on TSB)
This is a ghetto way, but it will solve the problem and then later on you can go to the dealer an let them handle it or at least until you buy some foam insulation tape. Cut a paper towel to match the length and fold a couple times to make it thick. Stick the paper towel in the gap in use a small flat-head screw driver to push it down more until its hardly visible from the drivers seat. The only time you see if is when you look directly on top or if it happens to be a sunny day and you get a reflection on your windshield.
Like I said, this is the ghetto way works foe mea
Old Feb 2, 2002 | 06:55 PM
flerve's Avatar
my tweeter rattles in my passenger side a piller. ive been meaning to just take it out since i have my tweeters installed in my door now... it only happens once in a while, not all the time, and it did it back when i was still using it as a speaker also, but im pretty sure it is the tweeter rattling.
Old Feb 3, 2002 | 10:02 AM
MichaelAE's Avatar
Re: Re: A-Piller Rattle (not on TSB)
What gap are you referring to? That sounds like the fix to the TSB A-Piller "squeak" which I am not experiencing. I'm not sure this will make a difference, but maybe.
I'm thinking the suggestions about an A-Piller clip or maybe the tweeter is loose. Its not the speaker itself...I'd recognize the sound of the speaker itself rattling...this is different. A distinctly metallic rattle that I was almost positive was the VIN plate.
Old Feb 3, 2002 | 11:54 AM
Loe max's Avatar
Re: Re: Re: A-Piller Rattle (not on TSB)
Press on the A-pillar while you drive. If it stops, its comming from that area. Follow the steps I prescribed above If you pressed on the VIN plate and the sound didn't stop, more than likely that's not the source of the noise.
Old Feb 3, 2002 | 09:00 PM
TimW's Avatar
The silent but deadly Moderator
hmm
you sure its not your window controls? mine rattle and it sounds like its coming from the a-piller.. when I touch them, it stops. other people have noticed that as well
Old Feb 4, 2002 | 09:02 AM
MichaelAE's Avatar
Re: Re: Re: Re: A-Piller Rattle (not on TSB)
What gap were you referring to when you said, "Stick the paper towel in the gap?"
Originally posted by ScreamingVQIf you pressed on the VIN plate and the sound didn't stop, more than likely that's not the source of the noise. [/B]
No $hit sherlock. j/k
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
