Plea for help
Old Mar 7, 2018 | 06:00 PM
  #81
heuster's Avatar
Can anyone tell me where the grounds are on this car and how I should go about checking them?
Old Mar 7, 2018 | 06:48 PM
  #82
maxiiiboy's Avatar
Ground distribution is described in the EL section of the FSM. It starts on page EL-18.
Just a few hints: All Maximas use "negative ground", where the negative terminal of the battery is connected to the chassis, engine, and transmission. In fact, the ground is distributed via the various harnesses to all the points shown in the diagrams on pages EL-18 to EL-22 (perhaps 10 dozen points).
To check ground distribution, you measure the resistance between the two points of interest: This resistance should be zero, or at most a small fraction of an Ohm. In practice, focus on a few selected/critical points:
- Negative terminal of the battery,
- The grounding point on the top of the engine cover, passenger side,
- Transmission and/or starter.
However, I feel quite strongly that you are again getting sidetracked. As I stated & explained in my earlier post (#69), your harness is messed up, and you need to restore it to its original/OEM state (unless you can get the documentation from the original owner). I am switching out&off until you do that.
Old Mar 11, 2018 | 05:33 PM
  #83
maximatech12's Avatar
Oh man - your losing me on the circuit test, but as for the MAF unplugged....if I unplug the MAF the car starts right up - no extended crank, no delay, I just can't hit the gas or it sounds like someone put their hand over the mouth of the throttle body.
right you have the 2000 M/T
This was from The 2001 A/T model
i wouldnt put my hand over that while the engine is on! You could **** your hand pretty bad!
Old Jul 15, 2018 | 01:44 PM
  #84
heuster's Avatar
Solved!
Issue with the idle problem and all this crazy behavior is gone. Ended up taking it to a shop that specializes in electronic diagnostics, but they isolated the issue to a metal clip on the door jam cover that had been pressed into the wiring bundle running down the drivers side of the car. It was shorting to ground the 5v reference wire to all the sensors. When the former owner wired the stereo they must have done it and it just got worse over time and use and people getting in and out of the car.
Anyway, thiughtbyiu all would want to know. I still do have an idle issue that I will start a new thread for that has to be related to replacing the TPS and/or MAF as this idle issue was not present prior to all of this going down. If you know of anything that should be done after a new MAF or TPS let me know!!
Thanks for all the help!
Old Jul 16, 2018 | 10:37 AM
  #85
Tarzan's Avatar
A-ha. Pinched harness.
Glad it worked out.
Old Jul 16, 2018 | 12:16 PM
  #86
maxiiiboy's Avatar
Great, glad to see you got this one nailed down.
It should be much easier, now that you only have one issue (presumably your MAF) to worry about.
Old Jul 18, 2018 | 10:48 PM
  #87
CMax03's Avatar
Originally Posted by Tarzan
If you have an idle at 600 RPM and you press the pedal and it only goes no further than 650, then the ECU is not hearing from the pedal. This was my experience when the TPS in my Quest developed cold solder joints. You replaced the TPS, so assuming that the new one was good, there is likely no connection to the ECU further up the harness, or in the ECU itself (unlikely).
But if like Wes wrote, you only go up to 2500 when in gear, that's the limp mode, and the cause would be different, like ECU not hearing from the CPS - crank or cam.
There would be codes for each after like 2-3 minutes of idling if this was a VQ engine, but I am not sure if 3.0 should throw codes as well. IMO it should, just not sure.
If the ECU is receiving inputs from the Cam or Crank sensor the car will die!!!!!
Old Jul 19, 2018 | 12:46 AM
  #88
heuster's Avatar
MAF has been replaced along with TPS. What steps should
be done under normal conditions when you replace MAF? Replace TPS?
Geronimo
Sep 17, 2016 03:01 PM
Roachjuice
Apr 8, 2016 05:55 PM
viking1
27
Aug 14, 2011 05:31 AM
dkillahster
Nov 17, 2009 07:57 AM
Tee00Max
Mar 31, 2009 03:47 PM
