Lower Rad Support
Old Feb 16, 2018 | 08:42 AM
USMC6004's Avatar
Lower Rad Support
For those that already replaced the tie bar, did you have to remove any or the A/C components?
Old Feb 16, 2018 | 04:33 PM
95naSTA's Avatar
No, just hang it up.
Old Feb 16, 2018 | 06:23 PM
maximatech12's Avatar
lower radiator support? Tie bar im thinking rear suspension.
Yeah I removed both radiator&fans + AC condenser.
By removing these you will have more clearance to carefully drill the inner welds that attaches the thing to the subframe.
Why you going to perform this on a 5th gen ?
Old Feb 17, 2018 | 06:45 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Yeah I removed both radiator&fans + AC condensor.
Rad support rust out fast in upper states, I moved from Florida to PA and will be replacing the rad support soon, found some rust on mine.
Old Feb 17, 2018 | 08:19 AM
SubwayVQ's Avatar
Unless it has started to collapse and it’s sinking/completely destroyed, I wouldn’t worry about it. Mine has a 5 inch hole, but it was still able to support the car when being jacked up. Obviously I don’t jack it up there anymore, but it means it still has integrity. I’m not replacing it until it absolutely needs to be done
Old Feb 17, 2018 | 09:55 AM
Good choice! I did mine last year and afterwards the hood now is solid instead of vibrating at highway speeds.
check out Conicelli parts for a nice price on that! You can just replace the lower section and either bolt it on or weld. Obviously welding around wires, sensors, ect, is not really smart.
What I did was bought truck bed paint and coated it to prevent further corrosion
pocketrocket
Mar 8, 2010 11:34 AM
BigLou93SE
Feb 18, 2009 01:50 PM
prince_starbai
18
Sep 19, 2008 06:10 AM
andrei3333
54
May 21, 2007 05:33 AM
