My 02 i35 lost power on the freeway!
I'm driving along the highway when i gave the car mid throttle to gain speed up to 70 mph. There was a surge of power, then hesitation, and another surge to 75 mph where all of a sudden the speed started to drop and would not accelerate anymore.In a panic i got off the exit ramp and coasted to a stop where the car jus died. No check engine light. Prior to this it has never happened before only when my alternator went out. It sat for 4 days over the weekend. Started up fine today. I also swapped the maf sensor before starting it today. I topped off the oil and checked the coolant before driving it like i do everyday. So after it stalled I'm just sitting here until it cools down a bit. Hopefully it's a simple fix.
Well after sitting for an hour she started back up with me pressing the gas pedal a few times. So i drove to my destination about 5 miles away when the engine light comes on. Now i have noticed that the floor seems to get very hot at times and also flooring the car is not an option because it boggs down so i believe the bank one cat maybe clogging up. The bank 2 cat is gutted so i always get a 430 code. But the codes were camshaft sensor timing over advanced. P0011 and p0021?
if thats the case it must have been a pending code from the last time i drove it. when ii checked oil today it was a half quart low, so i added more before i drove it.
Ok i will look into that .i did remove the bank 2 cam sensor a few days ago to try and replace the oil seal around it and accidentally dropped it on the ground
sadly they are pricey and OEM only, or u are going to waste time. but def look into all 3 sensors 2 cams 1 crank
Ok i definitely will look into replacing all three sensors. Because it's starting but taking slightly longer than normal and drives good but feels like it will shut off/stall at a stop, but then it catches itself as not to shut off.
my only symptom (and only one time out of the 10 times mind you) to indicate it may happen was my oem Bose unit flickered its LED letters (where it says tape or fm or cd)
sensors used to come in a 3 part kit at a better price but no more, and i cant stress enough OEM, or go home ( i wasted my time the first go around and even though I asked for OEM, got napa aftermarket, and tried the aftermarket napa, and it came back in less than a years time
you are telling me, my maxima has been DD from day one.
ridesurfer
05-01-2014 06:02 PM
95Maxed
45
01-26-2012 11:17 AM
