Items on my 7500 mi checkup
Old Feb 2, 2002 | 08:17 PM
woosh's Avatar
After my 7500 mi checkup I just kinda blasted out the door with my six. Inspecting the write up sheet , can someone tell me what the hell are these:
- check antifreeze and adjusted as necessary
- set timings
- Inspect HC/CO
I can understand adding anit-freeze but how the ehll do you tell the % it needs. Do they just mean added 50/50?
set timings for what?
HC/CO what is this?
Are they full of it?
Old Feb 3, 2002 | 01:40 PM
woosh's Avatar
Re: Items on my 7500 mi checkup
- set timings
- Inspect HC/CO
HC/CO what is this?
bump! Sprint?
Old Feb 3, 2002 | 09:05 PM
theMax's Avatar
- set timings
- Inspect HC/CO
HC/CO what is this?
for the antifreeze you can get a tool for about $1 and looks like an eyedropper. Tests the amount of antifreeze.
The dealer probaly has a better one. I think its called a hydrometer.
As for the timing, probaly reset the ECU.
Not sure that the HC.CO is?
Old Feb 3, 2002 | 09:09 PM
theMax's Avatar
Just noticed your sig pic, didnt you have a sterling mist 2k1??
Old Feb 4, 2002 | 06:08 AM
njmaxseltd's Avatar
- set timings
- Inspect HC/CO
They added antifreeze if it needed it. I doubt they checked the concentration level of it. Some new cars could have air pockets in the cooling system which purge out after they are driven.
Set timings? Must be a Nissan term
HC/CO - Inspect Hydro Carbons and Carbon Dioxide. Basically they stuck the inspection sniffer in your exaust to make sure your emmissions were OK.
Old Feb 4, 2002 | 08:59 AM
woosh's Avatar
No, wish I had waited then it woulda been. where can I get one o those hydrometer things to buy?
The sig is what I imagined the skyline GT-R kit would look like if they made one 4 the max. (Sweeeet)
Old Feb 4, 2002 | 10:44 AM
theMax's Avatar
I got mine at a gas station for 99 cents. You dip it in the coolant and it tells you what temperature your coolant can protect to by counting the number of ***** that float.
A more expensive one will also measure max hot temp as well as low temp. Go to any autoparts store and ask for a hydrometer to check the coolant.
Here is a how to.
http://www.ridgeap.com/tips/auto_cooling_systems3_4.htm
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
wiseguy6199
18
Oct 1, 2015 12:28 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
