03 I35...Worth The Hassle?
Old Apr 12, 2018 | 03:18 PM
ukmastermind's Avatar
Interested in buying an '03 Infiniti I35 w/90k.
Been reading about all the problems with fried ECU's, bad IACV valves, & timing chain guides. Is it worth the hassle?
-During a test drive, the transmission randomly slipped a few times for a few split seconds. Not sure if its a fluid issue or something more serious.
Overall, car looks good, $2000 was the lowest I could get them down.
Thoughts?
Old Apr 13, 2018 | 07:15 AM
Derrick2k2SE's Avatar
They're very good cars over all. The IACV and ECU issues were on the 3.0 cars. The 3.5 doesn't use an IACV at all.
The timing chain issues are on the 6th gen maxima when they changed the guides. The VQ engine up to 04 is bulletproof when it comes to timing chain/guides.
The 3.5 can have oil burning issues. That's about the only thing I'd research. You can find a bunch of info on it on this site. At 90k you may still be able to prevent it.
Old Apr 13, 2018 | 09:11 AM
mclasser's Avatar
Could be a solenoid issue or dirty/low ATF. These cars are pretty common so I'd personally look at another one.
Old Apr 13, 2018 | 11:34 AM
No kidding? What does the 3.5 use in place of the IACV? ECM control?
I guess I could try having the ATF replaced to see if it makes any difference. Seems like a nice car
Old Apr 13, 2018 | 05:14 PM
The 3.5 uses a drive by wire throttle body which is fully controlled by the ECU. No throttle cable at all. It's a pretty solid system for the most part. I had to replace the throttle body somewhere around 200,000 miles. Not too big of a deal. It also doesn't like the have the butterfly valve messed with so no manual cleaning even if it's unplugged.
Old Apr 13, 2018 | 06:15 PM
maxinout93's Avatar
not a bad price, But they do use oil and require more attention so if your not mechanically inclined then id stay away. Overall very good cars with the exception of oil usage.
Old Apr 14, 2018 | 04:46 AM
colt149's Avatar
I bought my maxima 2002 SE Automatic with 104,000 miles on it on 2013. The first thing I noticed is slipping of transmission. Totally fix it by dropping the transmission pan, spray contact cleaner to the solenoid loaded with sludge. Replaced transmission oil with AMSOIL Synthetic Transmission Fluid, since then up to this date the ATF is still Blood red in color.
Old Apr 15, 2018 | 12:46 PM
The car is pretty clean and looks pretty nice compared to my 95 maxi. I'm going to change the ATF and see if that helps. Owner is willing to go lower on the price if the tranny fluid trick doesn't work.
Old Apr 17, 2018 | 06:48 PM
maxinout93's Avatar
Kool a big upgrade from the 95 maxima
Old Apr 18, 2018 | 01:04 AM
wellshii19's Avatar
There's a guy who does manual swaps,you can find him on youtube.
or if your inclined to do so so it yourself. lol
2k isnt bad for 90k mile car. Hows the rest of the car?
I mean any used car,even Toyotas are going to have their problems ,whether timing chain guide issues or whatever. Hell beats 16k and up on a new car any day IMO.
Old Apr 20, 2018 | 02:33 PM
Rest of the car is in good shape. Paint still shines, no damage minus a few scratches.
Old Apr 21, 2018 | 08:16 AM
2k2albatross's Avatar
I have had my 2002 Maxima since 2004. I will reiterate what Derrick2k2SE said already regarding oil. I was able to eventually stop the extreme oil loss in my situation with a new rear valve cover.
Old Apr 23, 2018 | 10:13 AM
Aside from the leaking valve cover gasket, does this engine burn oil? I'm guessing that's what all the oil issues are about?
Old Apr 24, 2018 | 05:46 AM
Some of them have actual oil burning issues as opposed to leaking issues. A search of the 5th gen forum will cover a lot of the ideas as to why.
A lot of people say the pre-cats break down and suck abrasive material into the engine. I'm inclined to believe that since I removed the pre-cats around 90,000 and I burn very little oil even after 235,000 miles.
Old Apr 24, 2018 | 02:51 PM
maxinout93's Avatar
Most of the time people have oil leaks there are many places on this engine where over time oil can leak, some of the engines burn oil. But best thing to do if you are going to buy the car is to check the oil everyday or every other day. Keep in mind that once you start the car you have to wait at least 20 mins before you can pull the oil stick and get an accurate reading.
Old Apr 24, 2018 | 05:47 PM
LQ91SE's Avatar
Good advice. Also check both power steering hoses (pressure/return). Any small leak drips onto the front lower control arm bushing and ruins it. You then end up with front end "clunks" and alignment/steering issues.
Old Apr 25, 2018 | 01:19 PM
All good to know. I will keep you posted
DipreSantana
Apr 14, 2013 08:14 PM
Logan30
80
Feb 9, 2013 11:56 PM
Kryogen
May 7, 2011 07:32 PM
canIlive
May 9, 2010 07:52 PM
geoff.doctor
28
Jul 19, 2005 12:31 PM
