TransGo Shift Kit= Slipping Cure
Old May 4, 2018 | 03:23 PM
ukmastermind's Avatar
Was talking with a "Nissan Specialist" who suggested that I install the TransGo Shift Kit if I have slipping problems. He claims that it will cure the problem and preserve the transmission.
Based on what I've seen on this forum, the kit saving the tranny only applies to rebuilt ones or ones with no history of problems.
Do you think the kit will save a "slipping" transmission?
Old May 4, 2018 | 03:44 PM
nestorlugo's Avatar
I'll say yes and I have one for sale
Old May 13, 2018 | 03:14 PM
kauaiwyatt's Avatar
It didn't save mine. I had a bad 2-3 slip, and it got worse after I added the shift kit (it helped make the slip less noticeable tho). I'd suggest getting a 6-speed swap or a junkyard trans + the shift kit (but a j/y trans could have a slip. It's a gamble). Or go with IPT transmissions which is what I have (everything but the torque converter), and it's awesome. My friend sold me this trans which was rebuilt with the IPT rebuild kit + modded VB + IPT shift solenoid pack. It shifts hard & fast. http://www.importperformancetrans.co...rts.-54-1.html
Old May 14, 2018 | 10:28 AM
Tried changing out the ATF and the 2-3 slipping has improved but it's still there. Is this just a weakness of this transmission? What do rebuilds go for these days??
Old May 14, 2018 | 01:47 PM
maximatech12's Avatar
Did you back flush the cooler lines? They could be plugged up with dirt.
Old May 15, 2018 | 04:48 AM
Prophecy99's Avatar
also an auxiliary tranmission cooler isnt a bad idea either, first thing I got on the max.
Old May 15, 2018 | 10:50 PM
Donkeypunch's Avatar
Does the tranny have a thermostat or does it always send oil out into the cooler?
Old May 16, 2018 | 04:37 AM
Prophecy99's Avatar
My auxillary cooler Haded 404 does not have a thermostat, but some do. dont think OEM / stock one does.
I am in the NE, and the only small con is extra cold/hard shifts on morning commutes before anything is warmed up in only the winter time, but after 11 years, it hasn't been that bad with out a thermostat. i only remember or notice it when I get on it on the morning within the first 5-10 mins of driving...
Old May 22, 2018 | 01:42 PM
From what I understand, the radiator was replaced so maybe the lines were flushed.
I went thru several gallons of ATF just to get the color a little more red!
SmokinMax02
18
Sep 11, 2015 12:25 AM
allensteiner21
Nov 16, 2008 08:34 AM
JAIMECBR900
Apr 27, 2002 05:04 PM
pinhead139
Oct 3, 2001 08:17 PM
CHI99Limited
Aug 31, 2001 03:19 AM
