Alignment after Wheel bearing replacement?
Old May 29, 2018 | 10:37 AM
Andrew's Avatar
Hey all,
I'm going to replace the drivers side wheel bearing and hub assembly. But here's my question. Do I need an alignment after I take off the knuckle? I can remove the bearing from the knuckle and press it back in while its still on the knuckle, but it would be easier to take the entire thing out.
The only reason why I'm asking back in the day, when I did my struts on another car (Pontiac), when I took out the strut bolts is moved the camber drastically.
Thank you!
Old May 29, 2018 | 11:59 AM
95naSTA's Avatar
Yes, you will need alignment if you unbolt the knuckle. If you separate the ball joint, remove the axle from the knuckle, you can press the bearing in/out with the right tool. I've done it a couple times borrowing a tool in order to keep my alignment. It is harder to do it in the car but not by much with the right tool.
Old May 29, 2018 | 11:43 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It's not going to change toe, so why bother? That's the only thing that can be adjusted. It's a waste of money.
Old May 30, 2018 | 04:57 AM
95naSTA's Avatar
The play in the knuckle bolt holes and the how the strut tightens up on the knuckle can change toe and camber. FWIW, I've actually done alignments.
Old May 30, 2018 | 10:24 AM
Andrew's Avatar
I ought so. I also worked in an alignment shop many years ago but forgot. But I remember doing the alignment on my car after replacing just the struts.
I do have tool to press the bearing in and out while on the knuckle though. Just would be easier to take out the knuckle and press it out and in while its out.
Old May 30, 2018 | 09:53 PM
Genes1s's Avatar
Unless you can put everything back together and keep the geometry the same, alignment isn't a bad idea.
Old May 31, 2018 | 01:12 AM
Bad *** Newb
Except it still doesn't matter. I've driven for many thousands of miles personally (and others that I maintain) with no difference. They still drive straight and tires wear completely even. Not that there's much play for camber, but that can be made exact by lining it up with the outlines of where the nuts were. I can replace the entire knuckle, switch to coilovers, etc, it doesn't matter (I have completely shot arms on one car and wearing is still even). If I don't replace the control arms and the car is aligned well, then it's not getting done. ****'s not cheap if you haven't already got the "warranty". Hell, if you take the time you can replace tie rods and get the alignment back dead nuts.
Old Jun 4, 2018 | 10:15 AM
Andrew's Avatar
I had to take the entire knuckle out. Who know those stupid retaining clips were a *****..and on BOTH sides?!? Any easy way to take them out? Me and my dad almost had a heart attack taking those things out.
Old Jun 4, 2018 | 12:12 PM
rodent_infested_03's Avatar
I just failed NH inspection for a bad drivers side wheel bearing. I lifted the car, shook and turned the wheel, can't find any play or rattles. The grinding is rusty rotors because the car sat for 3 years in the mud. Wondering what your symptoms were.
Old May 14, 2021 | 02:14 AM
Ryan S Mower's Avatar
Hub assembly replacement
I replaced my hub assembly. Removed tie rod and ball joint on lower ctrl arm to do it. Camber Hella off. What bolts do I need to adjust to fix it?
Old May 14, 2021 | 05:26 PM
User1's Avatar
Camber changes would have been the amplified by the slight amount of slack in the two lower strut bolts which fasten the knuckle. Pushing the top of the knuckle inward, or pulling outward while the bolts are in place but not torqued will result in a slight, yet notable camber change. I have played with this on mine. Beyond that, there is no official camber adjustment on these cars.
Old May 15, 2021 | 05:38 AM
Shock mount bolts. Did you tighten everything up while the car was still in the air?
Old May 15, 2021 | 09:27 AM
95naSTA's Avatar
FWIW camber changes toe also.
Everything I said above is accurate and this thread shows it.
sicivic89
Jun 25, 2008 02:13 AM
goon9
Jun 19, 2006 05:21 PM
boondoxmax
Oct 25, 2005 09:33 AM
pjalst
Dec 5, 2003 06:08 AM
