Radiator fan
Old Jun 2, 2018 | 09:09 AM
oren's Avatar
Radiator fan
Hello friends
after replacing the defected radiator i have noticed that only the left fan is working if i turn on the AC or if i"m waiting for the engine to warm up.
is it normal ?
when the right fan should start working ?
thank you very much for your help
Oren
Old Jun 2, 2018 | 10:11 AM
03VQMAX's Avatar
The right should go on before the left. I believe
Old Jun 2, 2018 | 10:52 AM
DennisMik's Avatar
Both fans should come on at the same time. There is only one control signal that goes to both fans simultaneously.
You have a bad fan.
Old Jun 3, 2018 | 03:58 AM
oren's Avatar
Problem solved (for now...)
Hello Friends
Embarsed to say that it was just burned fuse, problem solved and the 2 fans are working.
Will keep an eye on the temp just to be surtain
thanks
Oren
Old Jun 6, 2018 | 04:55 AM
maximatech12's Avatar
Originally Posted by oren
Hello Friends
thanks
Oren
I just replace both of my fan motors on my 2001 maxima A/T.
The temp should be always below 203ºF
the symptoms that led up to me replacing both of mine were
the one fan spins sometimes and the other fan spins sometimes but as the temp went to 214ºF they both would spin on a hogher speed.
The fans are to both begin spinning at 203ºF or when the A/C is on.
They fail intermittenly.
Old Jun 7, 2018 | 08:47 AM
DennisMik's Avatar
Coolant temperature is usually no more than 203º but under certain conditions could higher. That's why the fans have a high speed that kicks in at 212º.
Under normal conditions, you will see the coolant temperature constantly going up and down between 180-190º and 203º. The low end number varies based on the thermostat's operating characteristics.
peb396
Jul 25, 2015 02:52 PM
cabernet
20
Dec 20, 2010 09:51 PM
skyjay617
Aug 14, 2008 07:43 PM
2002 Maxima SE
Feb 24, 2004 01:45 PM
97max5spd
Aug 26, 2001 12:02 AM
