P0300 Help Please - Yes Ive Read the Threads lol. 2002 Maxi
Hey All - Just purchased my 5th Maxima (yes I have a problem). This car is a 6 speed an lived an otherwise easy, highway mileage, great climate (West Coast) life.
The car has the Dreaded P0300 Code..... The idle is rough along with ticking at idle, and the power is a bit "lumpy" in the lower rev range... or 5th/6th gear at low RPMs
Check out these 2 videos:
First - Revving the car up to the 2K mark... Notice how the SES light starts blinking at 2K and goes to a solid light after a few seconds (and lower revs)
Sound is most prevalent under the car along with a little engine rocking... Almost sounds like it's coming from the Cat area... But a Cat wouldn't tick right?
The difference with my car and what I read in previous posts is:
- My car Runs like a bat out of hell. There is no lack of power - no rev limiter feeling at 4,000 RPM.. (I forgot how quick these 3.5's are)
- The car is not in Limp Home Mode
- Coils are 1 Year old.... They were replaced (6) by the P.O. (Aftermarket online crap.... Booooo)
- Checked the front 3 coils today (with new replacement) No change.... Did the "pull the plug check" on remaining Coils except #1.... My hands are too fat to pull that plug
- Throttle body wasn't terrible dirty... It wasn't however at a perfect 90 degree angle which had me curious... Sprayed a bit of cleaner in the unit
- MAF looks fairly clean
- Car has a fresh belly full of 92 Octane
C'mon Maxima Gawwwds. Please help a brother out!
Thanking you all in advance.
First thing I'd do is try swapping the MAF. A failing MAF can cause all sorts of weird issues and throw them all under the P0300 code.
A vacuum leak can cause the rough idle and P0300 but still run great at higher RPM.
How many miles on the car?
What do the plugs look like?
I couldn't hear the ticking but my speakers suck.
I would look at the ticking separately from the code/running issue.
TBH I have not pulled the plugs. Think its a good time to check them out? Also - Where is the best place to buy a MAF these days besides the dealership?
Probably original plugs. Pull the easy ones and check the gap. Also, people have changed the front plugs and left the two hard ones in the rear before.
Rockauto.com for a Toshiba MAF or your local You-Pick-It yard if you have one near by. Grab two used ones if you can and see what they do. Even if one is bad it'll probably screw up in a different way.
So the car has about 152k. P.O. said that he always used Mobil One Full Synthetic. At Most he has added 1 quart between oil changes.
That would be a unicorn if true.
UPDATE: Verified that the only code is P0300 (Before my long diatribe/list of parts I threw at the bloody car today)
I stayed up all night changing all plugs..... Yes....all 6 of the bloody things (Switched from BOSCH to NGK Iridium).
Also changed the PCV Valve (OEM Nissan) and cleaned the Throttle Body and Intake Manifold to high heaven. The old PCV valve was aftermarket and made minimal noise when "shaking it" as you all do.... Guess it paid its dues
Switched the coils from 1 and 3 to the front for obvious reasons.. I know these are good
Still shuddering/hesitation and rough from idle to 2700 RPM
Def. Not in Limp mode:
The shudder is lighter after the plugs.....and the engine feels a bit smoother; pulls to redline strong as pine-sol.
Time for a MAF (Rock Auto) and dare I say the beloved Throttle Body? This car is getting more attention than my side-piece or wifey
Cheers
Cheers
Nice looking car. I've always liked them in white.
Good choice on the plugs. I use those in all my cars. If it had Bosh then they're not the original plugs.
I hope you didn't screw the TB up. You're not supposed to manually operate the butterfly valve. Sometimes you can mess it up and sometimes you get lucky. If it's not acting up in any new ways you probably got lucky.
Good.
It could be the TB. I had a similar issue with my TB where it would stumble and stall at idle but run well at higher RPMs. It never threw a code for it.
My first guess would be MAF because it's known to throw the 300 code without any MAF codes. It's also cheaper and easier if we're just trying to rule things out.
Good.
ConcordMaxi
01-18-2018 06:15 AM
6cyl-97maxima
96
05-06-2014 10:28 AM
wyche89
125
11-25-2011 10:14 AM
super6
04-13-2006 03:12 AM
cptn_zippy
20
04-04-2005 10:51 AM
