Strange Auto Transmission behavior
Old 08-08-2018, 05:46 AM
rodent_infested_03's Avatar
03 GLE auto. At 70-75 the tach is around 2500. If I let off the gas it wants to slow down fast. As if it were a standard. Or as if there was no overdrive. Is this normal for this transmission?
rodent_infested_03 is offline
Old 08-08-2018, 03:17 PM
DennisMik's Avatar
An auto trans car at 2500 rpm should be doing about 72 mph. That's with overdrive engaged. When you say the car wants to slow down fast is a subjective statement. There is a lot of wind resistance at 70 mph, so that would slow the car down. I'm guessing that what you are experiencing is normal.
DennisMik is offline
Old 08-08-2018, 10:20 PM
maxiiiboy's Avatar
There is a significant difference in how much the engine breaks depending on whether the "Overdrive" is engaged or not. In Overdrive, there is almost no braking, and no slowdown when you let off the gas. Without Overdrive, engine braking is quite significant. The slowdown you are experiencing suggests your Overdrive is disengaged (or otherwise disabled). On the other hand, your RPMs (~ 2300 @ 70 mph) suggest that it is engaged. With this background, a few more rigorous experiments should answer your question.
maxiiiboy is offline
Old 08-10-2018, 08:56 AM
I checked again, and the tach is 2500 @70mph, close to 3k@ 80. The engine braking is very noticeable, more like a standard than an auto. Switching between 3 and D doesn't seem to make any difference. My other vehicles with 4 spd OD do not exhibit this. They are both around 2k at 70, with no significant engine braking letting off the gas.
I searched the forum to see if this has been posted before and there is a procedure to test that creates a flashing code via the AT light on the cluster. Not sure if i'm doing it right because whenever I try to do the procedure the car starts to roll away in D or 1, 2, etc.
Old 08-10-2018, 08:58 AM
Also noticed is if I step on the brake, the shift area of the center console makes a clicking sound.
Old 08-10-2018, 10:07 AM
maxiiiboy's Avatar
It looks like your OD is not engaging, or that your TC lock-up is not releasing. Is the red OD light on the instrument cluster ON or OFF?
Old 08-10-2018, 11:44 AM
I have not seen a red OD light since I have owned the car
Old 08-10-2018, 11:49 AM
The transmission fluid was really dark when I acquired the car. I don't think any maintenance was ever done on this vehicle. The shifting was really clunky so I tried exchanging a couple of gallons of Dex 3 through it. It helped the shifting a little bit but still engine braking at highway speed. Should I try exchanging another couple of gallons through the transmission cooler return line and see if that helps?
Old 08-10-2018, 01:27 PM
maxiiiboy's Avatar
Yes. I would do 3 or 4 consecutive Drain&Fill's. Use Valvoline Maxlife ATF; it's fully synthetic and only $17.97/Gal at your local Walmart. Also, if you want to be really diligent, drop the AT pan and clean the magnets and the filter.
Re. the RPM metric: On my car (2000 SE/AT): 2000 RPM at 60 mph, 2200-2300 RPM at 70 mph.
Re. the OD light: The light (and the OD itself) are controlled by the OD toggle button on your AT handle. The light should be ON (orange) when the OD is disabled, OFF (not lit) when the OD is engaged.
Old 08-10-2018, 07:55 PM
J P D's Avatar
At 2500 rpm my 2000 SE/AT does 74 mph w/the button OD.. Same rpm gets me 80 in 6th with the 2002 SE/6M.
VQ30DE vs VQ35DE
J P D is offline
Old 08-10-2018, 11:44 PM
AaronL's Avatar
Do the same thing and put it in neutral. Does it slow down less?
AaronL is offline
smax96
08-15-2017 01:16 PM
zoutv
39
01-01-2013 02:01 AM
MaxDriver98
08-10-2003 07:41 PM
milellie111
06-25-2003 08:25 AM
RBa
18
01-17-2001 05:27 AM
Quick Reply: Strange Auto Transmission behavior
