Hood latch no longer has support
Old Aug 25, 2018 | 10:00 PM
mxl555's Avatar
A friend has given me his 2001 Maxima, but the hood can't lock due to rust on the bottom end of radiator. The hood latch is no longer supported. Just trying to figure out cheap options to keep the hood locked down. This will be short distance A to B car for school.
I'm considering using climbing clips and maybe a chain/steel wire and tie it somewhere to bottom.
Old Aug 25, 2018 | 10:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You can slam it down and it will latch. But you should reinforce/repair the rad support. If it's not totally trashed you could just screw a thick sheet metal/plate across it, then screw the latch support to it as a quick fix. If you know someone that can weld have them fix it up.
Old Aug 26, 2018 | 02:47 AM
krismax's Avatar
Father of the 00 VI
It real unsafe to drive with the front of the crossmember hanging and not supported.
But if you don't want to fix it then use hoodpins.
Old Sep 3, 2018 | 06:22 PM
j8lech's Avatar
Hit it with penetrating oil until it latches and then buy this one from ebay for $20. https://www.ebay.com/itm/00-01-02-03...oAAOSwGltastF8 don't f around with broken hood latches, I had a faulty celica hood latch let the hood fly open at 40mph and smash the windshield Tommy Boy style.
ThaMax
Mar 27, 2010 06:23 PM
progrocker
Dec 18, 2005 11:55 PM
smokeyone
Jun 25, 2005 08:55 PM
unsprung
Oct 4, 2004 10:32 AM
PoePoe2797
Jan 9, 2004 06:43 PM
