P01574 and intermittent speedometer operation 02 i35
Old Aug 26, 2018 | 09:34 AM
maxinout93's Avatar
Ok it seems like one issue after the other, fixed the exhaust now the speedometers acting weird. It drops or stays at zero while I'm driving and other times it will come back on. It's showing a po1574, 1212, 10001 codes. I can't seem to locate the vehicle speed sensor if anyone has a picture of the location that would help.
Old Aug 26, 2018 | 10:48 AM
maxiiiboy's Avatar
The VSS is mounted on the transmission case. The AT section of the FSM has a picture although a not very good one.
Old Aug 26, 2018 | 12:42 PM
maxinout93's Avatar
Ok gonna take a look and see exactly where it is. Been to pullapart 2 times already and don't even know what I'm looking for
Old Aug 26, 2018 | 01:03 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Pretty sure it uses wheel speed sensors. ABS module could be bad.
Old Aug 26, 2018 | 02:00 PM
maxinout93's Avatar
It also is showing a code po500 wheel speed sensor A?
Old Aug 26, 2018 | 03:04 PM
maxinout93's Avatar
uhh been seaching this site and youtube and cant find any correct info on where the exact location of the VSS speed sensor is on the 02-03 maxima 02-04 I35. People are getting the different speed sensors confused. My 4th gen maxima vss went bad, no speedometer or odometer opereation. found it in the rear of the tranny by firewall. It is a sensor held in with 10mm bolt and has a gear on the end, the 5.5 gen is different. the hole with the 10mm bolt is there but its only a cap with no plug and no gear or anything. There has to be a speedsensor with a gear somewhere on the 5.5 tranny and im not talking about the revolution speed sensor or the turbine speed sensors which are the two under the driver side of the tranny.
Old Aug 26, 2018 | 03:40 PM
Bad *** Newb
I'm tellin ya, it uses the wheel sensors. Other people with your codes had a bad ABS module. They are known to fail, just isn't super common. Swappy time from junkyard.
I guess it's also possible that a shorted sensor could mess up the module, too, but idk for sure. The intermittent symptom says module failure to me, otherwise, I don't believe you'd throw all those codes.
Old Aug 27, 2018 | 03:29 AM
maxinout93's Avatar
yah it thowing the codes and transmission light seems to flash longer at startup, I erase the codes and they come back, but it does not light up the check engine light.
Old Aug 30, 2018 | 11:00 PM
maxinout93's Avatar
still getting the same codes now throwing the cel po500, po1212, and 1574 at same time. You guys are saying abs module but there are no abs lights on the dash saying that its bad, only thing is the transmission light (a/t light flashes like 16 times at start up) speedo works when i first start the car and drive it short distance in the morning, but after that its dead.
Old Aug 31, 2018 | 01:06 AM
Bad *** Newb
abs module controls speedo
Old Aug 31, 2018 | 09:45 PM
maxinout93's Avatar
Is it a difficult job to remove and replace the abs module?
Old Sep 1, 2018 | 01:23 AM
Bad *** Newb
no, real quick
Old Sep 2, 2018 | 07:17 PM
maxinout93's Avatar
no, real quick
wat about the brake lines. C
Old Sep 2, 2018 | 07:45 PM
Bad *** Newb
Not the ABS pump, the ABS computer.
Old Sep 3, 2018 | 08:28 PM
maxinout93's Avatar
ok im confused now. Where is the abs computer. Is it the thing that the large wireharness is plugged into on the abs pump? If so how do you remove it without undoing the brake lines?
Old Sep 4, 2018 | 02:56 AM
Bad *** Newb
You're right. For some reason I was thinking of TCM location, since it's easy.
You can remove the abs module off the pump, but I think you'll have to cut a socket to length to avoid removing the pump.
https://maxima.org/forums/5th-genera...bs-module.html
Old Sep 4, 2018 | 06:41 AM
Prophecy99's Avatar
nice find dude! how do u remember all this !
Old Sep 5, 2018 | 09:08 PM
maxinout93's Avatar
So if i end up replacing the entire pump. Is the brake bleeding similar to bleeding the master cylinder? Or is it another process ?
Old Sep 6, 2018 | 03:42 AM
Bad *** Newb
The only way I would do that is if I got one from the junkyard and capped all the ports. Bleeding the pump requires the dealer to do it.
Old Sep 6, 2018 | 08:10 AM
maxinout93's Avatar
oh gosh well im gonna leave well enough alone then and try to manuver the current pump assembly to remove the computer. I got one from a car a the pullapart but at the time i didnt know what size the hex head screws were.
Old Sep 9, 2018 | 07:01 PM
maxinout93's Avatar
Well I attempted to remove the abs computer module but only managed to get the top 2 screws out, Looks like one is rusted pretty bad so i didnt even bother to try and remove it. Looks like im going to have to just remove the lines and replace the entire thing, but i wont do it until i figure out how much its going to cost me.
Old Sep 9, 2018 | 08:36 PM
Bad *** Newb
If you remove it, then you can get the sucker off, I'm sure.
Old Sep 12, 2018 | 06:37 PM
maxinout93's Avatar
I mean like just replacing the entire thing with another unit abs control and computer, But I dont want to remove any brake lines if its gonna be a pain to bleed myself. But in my situation, that looks like the only possible way i can get it out of there, because the maxima and i-35 abs pumps are different smh.
Old Sep 22, 2018 | 02:33 PM
maxinout93's Avatar
Need some help in determining the best tool to remove these rusted bolts with
Buttinz
Aug 27, 2018 08:19 AM
jaykid806
48
Jan 27, 2006 08:57 PM
MrMaximaGLE
Oct 30, 2005 02:33 PM
][ 35
Feb 17, 2003 01:27 PM
MONTE 01&97 SE
Feb 14, 2002 08:14 PM
