Radiator fans
Old Oct 15, 2018 | 10:28 PM
Lrevans's Avatar
Radiator fans
How do I jump start my fans there not running car over heats if it sits in drive to long or if I go up hills
Old Oct 15, 2018 | 11:06 PM
Slamrod's Avatar
Try running a wire to the fan motor from the battery, obviously youre just touching it for a second to see if itll turn on. If it doesnt, then the fan motor is toast, meaning you need a new set of fans. If it does turn on, then perhaps you have a faulty relay. Could also be something very basic like a faulty connection as well. Try searching the forum (using the google search option) im sure this has been covered ten thousand times already.
Old Oct 16, 2018 | 06:52 AM
Derrick2k2SE's Avatar
I read your other post too.
The fans are probably shot. A lot of the original fans are failing now that the cars are aging. Most of us have had to swap them out over the last few years.
The relays rarely fail unless they've gotten wet somehow.
The plug has four pins. I forget which ones are which off hand. You can try hardwiring them from the battery to test the fan motor. Just play with the connections. You wont hurt anything. Keep in mind the fans may kick on only to fail after running for a few minutes.
You can replace the entire fan assembly or just the motors. If you really want to be cheap you can look through the You-Pull-It yard for a Maxima with new looking fan motors. I did this and stumbled across one that looked like they swapped fans just before giving up and junking the car.
Install is pretty easy. Go ahead and disconnect the top hose from the radiator side. It's tempting to try squeezing the assembly around it but it wont work. You'll only lose a few drops of fluid as long as you prop the hose end up.
Old Oct 16, 2018 | 10:02 AM
Turbobink's Avatar
Start on page 494 ... follow the "Without Consult II" procedures to diagnose your fan assembly.
http://www.boredmder.com/FSMs/Nissan/Maxima/2001/EC.pdf
Old Oct 16, 2018 | 10:34 AM
maximatech12's Avatar
they fail intermittently one minute they spin next minute theyre stuck and buzzing.
Old Oct 16, 2018 | 11:30 AM
CMax03's Avatar
Make sure they're shafts aren't just spinning in the plastic impellers due to heat damage...
Old Oct 16, 2018 | 01:01 PM
Turbobink's Avatar
This symptom leads me to believe that the fan assembly has failed and needs to be replaced.
You should be able to get a brand new dual fan assembly from your local parts store for about $135-$150.
Old Oct 18, 2018 | 12:38 PM
MaxMaximus's Avatar
Yup, your fan motors are shot, time to get them replaced. You can buy a whole fan assembly one piece unit at any auto parts store, or purchase just the motors themselves and replace those from rockauto.com
Here's a video that walks you through the whole process that helped me.
Also while your in there working, check your radiator for any leaks, I just replaced mine that sprung a leak.
Old Oct 18, 2018 | 07:44 PM
DennisMik's Avatar
Check the RAD FAN1 and RAD FAN2 fuses by the battery.
Old Oct 18, 2018 | 08:04 PM
User1's Avatar
Junk them and replace with this one:
https://www.jegs.com/i/SPAL/063/30102113/10002/-1
2500 cfm baby
Old Oct 19, 2018 | 09:34 AM
Child_uv_KoRn's Avatar
Bad *** Newb
TYC on amazon. Cheap as **** last time I ordered.
Old Oct 19, 2018 | 10:24 AM
Prophecy99's Avatar
yea I got mine from there too, entire thing (not just fan motor) , literally plug and play.
Old Oct 19, 2018 | 10:30 AM
Turbobink's Avatar
Thats what I got ... LLT to
JLA0117
Jul 13, 2016 10:24 PM
cspangg
Mar 13, 2011 05:46 PM
cabernet
20
Dec 20, 2010 09:51 PM
maxprivate
Sep 3, 2007 07:27 AM
