Question and parts ID
Old 12-12-2018, 08:08 PM
Mike88SE's Avatar
I installed a new negative battery cable. I was removing the bracket the ring end goes on and the 10mm bolt holding it on broke. As Nissan 10mm bolts seem to do. Often. Anyway I didn't want to fool w/ drilling it out so I relocated the bracket nearby on the same part. I assume it will be fine but I may run another ground from there to the block later on. I found a hose that isn't connected anywhere. It's coming from the transmission. Pic 1: I'm guess it's a vent? In the second pic is where I relocated the ground cable bracket I mentioned. If someone could ID parts A, B, and C for future reference I'd appreciate it.
Transmission vent?
New Ground cable bracket location and parts to ID
Mike88SE is offline
Old 12-13-2018, 03:58 AM
Bad *** Newb
Child_uv_KoRn's Avatar
Congratulations. You are the winner of the 1,001 poster contest to ask about a breather hose. Johnny, tell him what he's won!
Child_uv_KoRn is offline
Old 12-13-2018, 09:49 AM
Mike88SE's Avatar
Listen, I don't really mind the silly attempt at snarky humor but there were other questions there and since you bothered to reply at all you might as well have taken a shot at them.
Mike88SE is offline
Old 12-13-2018, 10:45 AM
Slamrod's Avatar
Is this a 3.0 or a 3.5? Part A is the sensor for your coolant temperature gauge on your dash, it is purely for your viewing pleasure. Part B is the coolant temperature sensor that your ECU uses, it has no interaction with your gauge. Part C is your coolant log, coolant runs through it, self explanatory. If you were looking for part numbers then unfortunately i cant help because im too lazy to dig them up lol.
Slamrod is offline
Old 12-13-2018, 11:27 AM
Mike88SE's Avatar
Thanks. Sender and CTS were guesses but now I know in case I ever need to know. I can find the part numbers if I ever need to. It's a 3.0. I'm guessing Nissan still uses the same vendor for 10mm bolts. In the z31/z32 world we used to say jokingly that all you need are a couple of different types of 10mm wrenches. And a drill with good bits and broken/stripped extractor set. I'm sure that relocated ground bracket will be fine. It's attached to the same part and actually made the body ground ring fit better. The one on the new cable was flipped 90 degrees from the original.
Mike88SE is offline
Old 12-17-2018, 05:43 AM
Derrick2k2SE's Avatar
Strange, I've never had a problem with breaking bolts on the Maximas or even my 1st gen Z Cars. The 85 Turbo ZX was another story. Kind of a low point for Nissan all around.
The ground will be fine there and,yeah, that's a tranny vent.
Derrick2k2SE is offline
Old 12-17-2018, 08:27 PM
Theslaking's Avatar
Yeah me either. Over 500k on 2000/01 Max doing all my own wrenching and don't remember ever snapping a bolt. Never heard of it either outside of people using impacts when they should not.
Theslaking is offline
Lrevans
11-05-2018 03:34 PM
ramlee
10-22-2009 11:10 PM
TJ_Max
44
07-27-2005 08:28 PM
Terran
11-13-2004 07:01 PM
Gen4Max
06-28-2004 04:50 AM
Quick Reply: Question and parts ID
