Maxima running hot
Old Mar 14, 2019 | 09:26 PM
Boo Brix's Avatar
Maxima running hot
I have a 2000 maxima and ive changed water pump,hoses,radiator,fan motors,thermostat,temperature switch,and fan coolant switch and my tempature gauge. My temp runs very higher than usual then the fans kick on and cool it down its not normal it use to turn on when it gets half way. The only code my car is reading is po420 i dont know if thats the problem or not but as long as my ac compressor is on i dont have to worry about it at all.if im driving it doesnt run hot but when im in park or jus sitting still it runs up any suggestion to help me figure out the problem
Old Mar 14, 2019 | 10:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You replaced the coolant sensor for the ECU?
I would verify with obd reader what the temp is. If the dummy gauge isn't lying, then the coolant sensor for the ECU must be bad, b/c the fans should kick on at 195, IIRC.
Of course, I also wouldn't rule out ****ty t-stat/air as a compounding factor (happens all the time, gotta test on stove and make sure fully opens at 180).
If sensor is good and fans kick on correctly, then it's a flow problem.
Old Mar 15, 2019 | 03:28 PM
fd3rew's Avatar
did you change out both thermostats?
Old Mar 17, 2019 | 11:10 AM
DennisMik's Avatar
If the temperature stays normal when the a/c is on, meaning the fans are running all the time, this seems like a fan turn on problem. I have to go with Child_uv_KoRn on the coolant temperature sensor (ECTS). You can measure the resistance in the morning before you start the car. Just unplug the wire and meter across the 2 contacts in the sensor. At 68º F, the resistance should be 2.1 to 2.9K ohms. If the temperature is colder, the resistance will be greater. 50º F will be around 3.5K ohm. An easier way is to use an OBD reader. It will report the temperature as the ECU sees it.
greenteam84
Mar 15, 2019 03:41 AM
aleksey17
Feb 2, 2013 03:21 PM
tcf_dk
20
Jan 22, 2012 02:37 PM
csb
Jun 24, 2006 03:43 AM
thebigsadler
Oct 12, 2002 06:21 PM
