Hitachi boost controller
Old May 1, 2019 | 07:20 PM
Santana777's Avatar
I recently bought an 03 6 speed .... 5th gen maxima, its has k&n intake and full stainless exhaust, for a few weeks it ran like a demon torque steer aside.. for some reason it now seems to not have the really strong power boost (broadband) that it initially had!! It would kick in around 3200 or so and run all the way through the range and stay there as I shifted then kept on pushing. I've pulled a p1800 code .. solenoid etc... I swapped that out and still the issue remains!! Has anyone heard of this elusive HITACHI BOOST CONTROLLER and where is it located? The only Hitachi anything I can find is on my throttle body and I cant figure this out please help??
Old May 2, 2019 | 06:08 AM
freezer's Avatar
1800 is VIAS solenoid which, if it is not functioning, will affect performance between 1800 and 3600 RPM.
If you've already replaced the solenoid you need to check the wiring. It's just +12V to the solenoid, and one wire to the ECU
Old May 2, 2019 | 07:20 AM
Slamrod's Avatar
+1. The solenoid is non-polar (as in, doesnt matter which prong gets positive or negative for it to function), so electronically speaking your only concern is that the power wire from the ECU is actually providing power. Mechanically speaking, it is also very simple - You can test solenoid function by jumping a wire from the positive battery post to one of the solenoid prongs; if it clicks when juice is applied, the solenoid is functioning as intended, where as no clicking would indicate the solenoid is faulty and must be replaced entirely. The last factor would be vacuum, as the solenoid controls a valve inside the intake manifold via vacuum. Make sure that your vacuum lines are connected properly (consult the FSM because i dont remember what tubes go to what hoses). If they are backwards, it wont function properly and youd probably have the exact problem you have now. Also check that your vacuum lines are not cracked, disconnected, or otherwise leaking.
OC_Nooby
Jun 29, 2012 10:34 AM
DcMaN
Oct 4, 2006 09:04 PM
Duckman540i
May 19, 2006 10:20 PM
1chewabacha1
Jul 20, 2005 05:44 PM
BigDogJonx
Aug 18, 2003 06:42 AM
