Steering mods
Old Jul 25, 2019 | 04:30 PM
wurmhole's Avatar
Steering mods
I am not a fan of the loose steering in the a33 maxima, I have compiled a list of fixes mods so far.
Solid steering column bushing
new tie rod ends
rack guide screw tightening
How much have these mods helped? Has anyone swapped in a different rack with a closer lock to lock ratio? Anyone removed the steering rack limiters under the boots?
Old Jul 25, 2019 | 04:57 PM
dizzykitty's Avatar
I think the SE has a different steering rack from the rest with more sporty ratios. Perhaps you could look into swapping if you don't have an SE.
Edit: Actually I know for a fact the SE rack is different, I just don't know by how much or whatever.
Old Jul 25, 2019 | 05:20 PM
wurmhole's Avatar
I have a gle with a manual swap in the works.
Old Jul 25, 2019 | 06:31 PM
dizzykitty's Avatar
My advice: change out your steering rack while the tranny is out of the car. It is a huge pain in the ***, but if your rack isn't leaking now, it will soon. Since you are looking in to tightening up your steering anyway, swap in an SE rack as well as inner and outer tie rods. If your steering still doesn't feel good, then try to mod the steering rack or whatever. My bet is you will be happy with an SE steering rack.
Old Jul 25, 2019 | 07:30 PM
User1's Avatar
I have new Moog inner and outer tie rod ends in my 2k3 SE. There's nothing loose about it.
Old Jul 26, 2019 | 12:42 AM
maxiiiboy's Avatar
Often, the steering feels loose because of poor alignment.
Old Jul 26, 2019 | 05:10 AM
wurmhole's Avatar
Is this true of 2002/2003 5.5gen maximas or just 5th gens? I tried doing some research but it looks like gle and se are the same for 5.5gens, unless anyone can point me in the right direction I cannot find any differences in steering ratios.
Old Jul 26, 2019 | 11:32 AM
dizzykitty's Avatar
You know, I am not sure. After looking around a bit myself, it looks like all models for the 5.5 gen share a rack. Another option would be to see if the SER spec-v rack will fit without much modification and install that.
Old Jul 26, 2019 | 07:52 PM
User1's Avatar
Same assembly for all models according to these guys:
https://www.nissanpartsdeal.com/part...492_A001,49001
Old Jul 29, 2019 | 07:24 AM
dizzykitty's Avatar
So I went on rock auto and checked the steering racks for a 2002. According to Cardone, the gxe rack has a lock to lock ratio of 2.94 as opposed to 2.63 of the GLE/SE of the same year. It would seem you do have the best steering rack offered. Still, I would check and see if there is any fluid in your tie rod boots and replace if necessary.
mango22au
Jan 13, 2006 07:58 PM
nick
Feb 28, 2005 02:51 PM
goodhead
Nov 26, 2004 05:57 AM
dgeesaman
Jul 29, 2004 10:04 AM
