Fuel gauge issues
Old Jan 9, 2020 | 05:49 AM
Tyler Ulmer's Avatar
Fuel gauge issues
Hello, I’m running into a strange issue with my Maxima. I have a faulty fuel gauge that’s throwing code P0462. I replaced the sending unit, and just recently had my instrument cluster tested which it turns out is ok. What else could be causing this issue?
Old Jan 9, 2020 | 07:39 AM
slvr2KSE5's Avatar
Wiring or a faulty new sending unit
Old Jan 9, 2020 | 10:28 AM
How would I go about testing the sending unit or wiring? I have a digital multimeter, but I’m not sure what to look for.
Old Jan 10, 2020 | 01:38 PM
freezer's Avatar
Who tested the cluster and confirmed it was OK? How was the test performed?How is your fuel gauge responding?
The "sender" is a actually a variable resistance drain to ground. Very simple to check with a multimeter, as is the wiring. Disconnected, the cluster will supply 12V to that circuit if its good or bad. Usually the cluster is where the fault lies. With the cluster connected and an 80 ohm resistor (empty tank) between the cluster and ground you should measure close to 4V. If the cluster has failed, you'd see around 2.4V
tseng1023
29
Jan 21, 2026 02:30 AM
Wakenbakon
Aug 10, 2018 08:43 AM
nardogb
Apr 26, 2015 05:44 PM
Jbeck
Jul 30, 2013 01:34 PM
Just the Max
Sep 19, 2012 10:34 PM
