Need Help Dropping Rear Beam/Axle
Old Jan 13, 2020 | 06:31 PM
Cephyr13's Avatar
2001 Maxima 5sp
I'm dropping the rear beam and the only thing I have left to do is get the trailing arm bushings to come off of the car. They're nice polyurethane bushings so I need them intact. They're stuck in the mounting bracket. In other words, the trailing arms are still connected to the car, but unbolted. The rear beam is fully unbolted and sitting on the ground with the trailing arms at about a 40 degree angle, going up to the car, stuck there. I've used a pry bar, but it's not hardly budging them.
Is there a trick to getting them to come out? I gotta get these bushings out ASAP.
Old Jan 13, 2020 | 07:39 PM
Slamrod's Avatar
Originally Posted by Cephyr13
2001 Maxima 5sp
I'm dropping the rear beam and the only thing I have left to do is get the trailing arm bushings to come off of the car. They're stuck in the mounting bracket. In other words, the trailing arms are still connected to the car, but unbolted. The rear beam is fully unbolted and sitting on the ground with the trailing arms at about a 40 degree angle, going up to the car, stuck there. I've used a pry bar, but it's not hardly budging them.
If you have new bushings to replace them, just burn them out with a torch.
Old Jan 13, 2020 | 08:31 PM
Cephyr13's Avatar
The trailing arm bushings are polyurethane. I need them intact because I'm going to press them out and put them on my other Maxima.
Tmars
Jan 20, 2013 10:03 AM
Maxident
Jun 29, 2012 02:29 PM
n3985
Jul 29, 2008 10:14 PM
