Engine making grinding/knocking noise
Old May 18, 2020 | 10:40 PM
rcruz1996's Avatar
I have a big problem and I need all the help I can get, I turned on my car today and once It got warmed up I noticed a weird grinding knocking noise coming from the engine bay. from what I think it might be the AC compressor timing chain or it has a bad pulley. I have uploaded a video so you guys can hear it what do you guys think.
Old May 19, 2020 | 03:20 PM
JvG's Avatar
JvG
I would try to isolate the sound first.
I would remove the serpentine belt which runs the alternator and air conditioning. The sound will stop if its one of those. Which would leave the timing chain related things.
Old May 20, 2020 | 12:56 PM
uptownsamcv's Avatar
those engines are known for being really reliable and not known for timing chain issues, I'm wondering if the cats are clogged up.
Old May 20, 2020 | 01:37 PM
rcruz1996's Avatar
I took it to the mechanics and the mechanic has no idea what the issue could be , today I will get the motor mounts replaced and the 2 belts replaced.
Old May 20, 2020 | 05:23 PM
JvG's Avatar
JvG
I didn't say to have the belts replaced. They might still be ok.
I said to remove the serpintine belt.
No point replacing engine mounts till you isplate where the noise is coming from.
I'm trying to save you some money.
Any good mechanic should be able to tell where the noise is coming from. Since this one doesnt, get a second opinion from a better mechanic.
Old May 20, 2020 | 07:50 PM
rcruz1996's Avatar
Great news no more grinding noise or knocking noise my car was due for motor mounts (it had the original mounts 200k miles), I bought all 4 motor mounts for $80 & the 2 belts. Once everything was replaced I started the car and let it warm up for 10min and no noise at all!!!!!!!!!!!! Drove it 30 miles just to make sure and everything sounds good
Old May 21, 2020 | 12:54 PM
Prophecy99's Avatar
maybe i should do my original mounts at 266k
Old May 22, 2020 | 12:36 PM
User1's Avatar
That sound was not mounts. I imagine the shop adjusted something/addressed some issue with/related to the drive belt system to solve the rattling but the OP isn't aware.
Old May 22, 2020 | 12:49 PM
rcruz1996's Avatar
I was there at the mechanic shop when they replaced all parts (4 motor mounts and 2 belts) , I think the reason why my car was making the noise was because the engine was sagging, passenger side motor mount was the worst of all of them. Belts were okay but it only cost me $15 in total for both belts on Rockauto.com
Old May 22, 2020 | 01:24 PM
User1's Avatar
Alright then, motor mounts it is. I've certainly been known to have been wrong before. Glad it's good to go. Take care of it and it'll go another 200k!
Old May 29, 2020 | 09:42 AM
sure is a weird symptom for bad mounts. normally i would just hear clunks and thumps...
MakkaPakka
Aug 23, 2018 02:00 PM
chiefy
Jan 5, 2017 11:29 AM
bennuss
Sep 11, 2015 05:55 AM
Harrison Nguyen
Jul 4, 2013 04:13 PM
James92SE
Sep 21, 2010 07:00 AM
