Maxima oil
Maxima oil
What is Nissans oil recommendation for there 6 cylinder? Just got a 2001 with 165000 on it and would like to get off to a good start. Just got some Denso pltinum plugs for it. witll take care of the air filter soon.
I run 36psi of high-performance, 78/20 Nitrox gas mixture in my tires. I also run an ultra high performance antifreeze which is largely composed of dihydrogen monoxide.
There actually was some studies done not too long ago that found evidence of Dihydrogen Monoxide being present in the pipes that bring people drinking water in every city they tested. Really scary stuff, people die from Dihydrogen Monoxide exposure all the time!
In fact, Russian MIGs powerplant systems use straight alcohol in their jet engine cooling systems. I makes sense, but is extremely dangerous;.
No joke:
https://books.google.com/books?id=YN...ystems&f=false
Vodka cooling systems. Makes perfect sense. Extreme phase change capability.
No joke:
No joke:
No joke:
You can regularly get castrol 0w40 on amazon for $15-16.
Quantity 6, One (1) Quart Bottles is what I got (5-W-30) and in store was $27.98 (A little less expensive than On-Line).
iv'e been running Penzoil Pure Platinum that is made from natural gas, suppose to be real good and since it's made from natural gas I would assume that's why it costs less than other synthetics. I get a 5 quart jug at my local walmart for $22 and some change.. as for tire pressure i run the max cold pressure that it says on the tire which on mine is 50 psi...
It's just your run of the mill hydrocracked group III.
See this gentleman who is using MOBIL ONE!
Get the EP or mobil 0w40 if you want mobil so bad. 0w40 has group IV base stock and is very competitive.
UOA's, Spoon Feed, EP, sounds to me that you belong somewhere else instead of these threads.
In other threads like my Toyota and BMW threads we call people like you that tells others "Not Spoon Feed" anyone and other cryptic acronyms is someone that Trolls and likes to feel superior to everyone.
No matter what your personal goals for being here, you are ZERO help and still not coming CLEAN with "ANY" Data!
