Bad Coolant Temp Sensor Causing Bucking?
Old Jul 9, 2020 | 06:54 AM
Cephyr13's Avatar
2000 Maxima 5sp 197k
I was having a horrible bucking problem to where I couldn't hardly drive my Maxima. It devolved to where I had to use the accelerator to keep it running.
It threw a coolant temp sensor code (my temp sensor is only 3 months old from AutoZone) and a MAF sensor code. So I replaced the MAF sensor and the car ran perfect again.
(Additional recent replacements: main cat, delphi fuel pump from AutoZone but not a new fuel pump housing, Hitachi ignition coils a year or so ago, and crank position sensors.)
Spark plugs looked good so they're not new, but they would cause misfires not bucking.
I checked the fuel pressure regulators and they're not wet with fuel at the vaccume hoses.
I replaced the MAF with a new AutoZone MAF to fix the problem and the car initially ran great. But the next day, I'm doing 70 mph and the car bucks a couple of times, suddenly. So the problem is still present to a degree. And when I drive for a while and let the car sit for a while before starting it again, it takes a while to start, almost like it loses fuel pressure while sitting.
I pulled codes and it's giving me the coolant temp sensor code still. My coolant overflow tank has coolant in it so I'm assuming the system is full.
Can a bad coolant temp sensor cause the car to buck hard? I've heard it affects cam timing and can cause that.
I don't suspect it's a broken pre-cats, but I guess maybe that's a slight possibility. I could, if need be, shell out the pre-cats just to test to see if they're the problem. But I'd rather get a more difinitive answer and or direction to go than just shelling cats for diagnostics.
Is it possible something caused the old MAF to go bad and the same problem is causing the new MAF to go bad now? The old MAF was only 1 1/2 yrs old.
Can fuel pressure regulators go bad without leaking fuel into the vaccum lines?
Any idea what would cause the bucking?
I gotta get this fixed quickly since I can't work without this car (it's a work-outfitted vehicle).
Old Jul 9, 2020 | 07:56 AM
ukmastermind's Avatar
I've experienced hard bucking at random times in two different cars (Maxima & Corolla) and both times it was a bad MAF sensor. It felt like the engine had an on/off switch and someone would randomly flip it.
Replaced both w/ OEM sensors and never had the issue again.
Old Jul 9, 2020 | 08:00 AM
Cephyr13's Avatar
I replaced the MAF with an AutoZone MAF and it was great the first day. But today, it's got the problem again, just not nearly as pronounced.
I get the idea that something may be throwing off the timing (coolant temp sensor) or there's a fuel problem. But I'm gonna be really ticked if something electrical is killing my MAFs.
Old Jul 9, 2020 | 08:05 AM
Prophecy99's Avatar
id say follow ukmasterminds advices, get OEM maf, or at least the OEM maf transitor, before you start guessing everything else is wrong.
i had a bad coolant temp senor, and had no drivability issues, only a check engine light.
Old Jul 9, 2020 | 08:36 AM
Cephyr13's Avatar
May have to...isn't it the Hitachi MAF?
Old Jul 9, 2020 | 11:40 AM
Correct. Hitachi is OEM.
Hopefully that will fix the problem
Old Jul 9, 2020 | 12:06 PM
Cephyr13's Avatar
Actually, just found out that AutoZone's Hitachi MAF is more expensive than the dealer's! lol
Old Jul 9, 2020 | 12:10 PM
Cephyr13's Avatar
Thanks!
Old Sep 2, 2020 | 12:17 PM
Prophecy99's Avatar
nice follow up post, good to hear
Old Sep 2, 2020 | 01:38 PM
Amave's Avatar
Originally Posted by benmickel
Here is an update in case someone else ran across the same issue and stumbled across this post. Since changing the sensor is significantly easier and cheaper than the whole thermostat housing I decided to start with that. After replacing the coolant temp sensor, the fan no longer runs continuously and the engine now heats up to about 205-210F and is stable. I also cleared out the codes with my OBD reader and so far they have not reappeared.
So you replaced the coolant temp sensor & the bucking has stopped?
jes0355
Jun 14, 2015 07:03 PM
D.Stillwell
Oct 10, 2013 10:44 AM
oms
May 21, 2012 02:39 PM
Paul S
Dec 26, 2011 07:59 AM
Sparhawk
21
Dec 4, 2002 11:25 AM
