02 maxima gutters and dies
As stated i have an 02 maxima and i got in the car one day, went to crank it up and it started strong, then immediately started to struggle and then it dies. If i try the gas pedal it dies immediately(no sputtering, just off) and it wont even start if i apply the gas. It had these codes at the time.
P0455-evap leak
P0420-cat bank 1
P0720-at veh speed sensor
P1574- automatic speed control device vehicle speed sensor
P144(is what i wrote down but i cant find that anywhere) vent control valve
So i replaced: --2 sensors located on the driverside of the trans(i believe are the 1574 and 720 they were the same kind of sensor) with 2 junkyard ones--1 02 sensor(bank 1 sensor1) with a new one.
After these repairs it still didnt start and popped 2 more codes(which i don't have on me right now) a high temp MAFs code and an IAT code so i cleaned the MAFS with cleaner and tried again. Same problem. I even went as far as to disconnect my lower cat just to make sure it wasn't blocking things up(cause i get a gas smell after starting)
The only code i havent done anything about, because i wrongly thought it was an interior AIR vent control valve, is the p144* code. But can a faulty vent control valve cause this kind of problem? Im at my wits end! HELP! I have pis of most of the parts etc that ive used, not sure if it would help.
P0455-evap leak
P0420-cat bank 1
seem like alot going on, the gas smell is your evap most likely vent control valve, but it wont cause a no start. Id start with the possibility of a bad camshaft sensor one or both. Also check to see if your fans are running when you start the car. I had that happen, the car would start when cold, and shut off right after and not start back up. Ended up being a coolant temp sensor. Not saying that is your problem but a possibility.
