Lost all my keys. Options?
Old Sep 21, 2020 | 10:31 AM
Whudathunkit's Avatar
I have lost my whole key ring.. I have to get a new key for my 2000 Maxima.. What are my options.. cheapest first please. TIA
I have called the dealership and they want 175 for one key and programming.. of course I will have to get the car towed to them for programming.. I would much rather order keys online and save that 45 for one key and maybe get a couple keys with at least one key fob. Anyone know if it is possible to order Genuine Nissan keys and fob from somewhere other than the dealership?
Old Sep 21, 2020 | 12:37 PM
Prophecy99's Avatar
our keys have computer chips, so its gonna be kinda hard to not go thru the dealership. i would just bite the bullet.
Old Sep 21, 2020 | 12:59 PM
Thanks.. Didn't know if there was an alternative or not.
Old Sep 21, 2020 | 01:30 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Buy blanks with chips on ebay. Have a hardware store cut em for free or close to it (tell em there's no chip if they're gonna be a *****). Program with Nissan Datascan 2.
Old Sep 21, 2020 | 01:35 PM
I have no key to go by to cut a new key at the hardware store. I lost all of my keys.
Old Sep 21, 2020 | 01:48 PM
TallTom's Avatar
The dealer is your only option at this point then.
Old Sep 21, 2020 | 06:04 PM
fd3rew's Avatar
One thing you can try, assuming all lock cylinder has the same number of pins as the ignition and assuming all your lock cylinders are keyed alike. If you can get inside your car, open the trunk and pop the trunk lock cylinder out and bring it to the locksmith, have them make you a key using your ebay chipped blank. After its cut, try and see if you can use it to turn the ignition switch to on. If it does, then all you need is someone with datascan or a simple key programmer and most locksmith should have a key programmer for the 2000 model year. There's no rolling security code based on body control module or what not for 2000, it's a fixed code. All keys you want to work will need to be programmed at the same time because, any attempt to program a new key will wipe out all your old keys from the body control module. So once you know you have a key that turns the ignition switch, get more ebay chipped blanks cut and find someone to program it for you.
Old Sep 21, 2020 | 06:13 PM
Thanks for your reply!
Old Sep 21, 2020 | 07:56 PM
Bad *** Newb
So bring your title and have dealership cut you a plain blank. It's not rocket appliances.
No doubt you're going to have some stealerships try to scam you, but you bully those idiots before they try to bully you.
Old Sep 22, 2020 | 09:43 AM
Thanks for everyone replying to my post. I have just found my keys... so now I must ask.. what is the most economical way to get a new key cut for both vehicles I own and would like to have keyfob for both.. which I've never had.. Both vehicles have chip keys. TIA
Old Sep 23, 2020 | 09:23 AM
LA02MAX's Avatar
I just had some new ones cut and coded on Monday at the dealership. It was $125 and it didn't matter if they were doing 1 or 2. fortunately I had 2, so it cost me about $60 per key for coding.
The keys I bought actually mimiced the old VW swtichblade keys, and it's really solid and works perfectly. I bought them years ago, but it's similar to this:
https://www.ebay.com/itm/ALLin1-FLIP....c100005.m1851
Old Sep 23, 2020 | 10:03 AM
Thanks so much for that info!!!
Old Sep 23, 2020 | 12:18 PM
Prophecy99's Avatar
nice find! thanks for sharing. ultimately OP you still need a dealership though =)
Old Oct 6, 2020 | 08:49 AM
RobertSteller's Avatar
Thank you so much guys for your help, i got one from an auto locksmith near me and it
Old Oct 7, 2020 | 04:33 AM
Theslaking's Avatar
My dealership only charges $99 to cut and program keys. That's what finally made me get datascan. Even though my dealership was cheap I figured I would buy the software instead and get all the additional benefits.
Old Nov 27, 2020 | 01:57 PM
uptownsamcv's Avatar
my car only came with the red valet key, which I keep in my car. I have 2 sets of chipless keys with fobs that I use to get in the car...
Old Nov 28, 2020 | 08:46 PM
koco's Avatar
Have any of you tried out the Silca SBB key programmer? It can be had for $80 to $100 ...beware of counterfeit ones though. This programmer can be used for many makes and models, and would probably pay for itself after a couple of uses.
Update: The Silca SBB works to program the existing key to a replacement used junkyard ECU. Instead of paying a locksmith $100, I bought the tool and DIY'ed it.
Old Dec 3, 2020 | 08:48 PM
krismax's Avatar
Father of the 00 VI
The cheapest way is to open the plastic where the immobilizer is, superglue your key on top of it. Then you can have keys made at home depot for $1or $2,. And you can have 20 keys for $20-$40.
Old Dec 4, 2020 | 11:27 AM
koco's Avatar
If I had it to do again I would buy a blank transponder key for $7 from eBay, take it to a locksmith to have it cut, then use Silca SBB or similar to program it to the car or maybe even nissan datascan software. As far as adding a remote fob you can add a new one using a sequence of programming steps while inside the vehicle...details can be found via Youtube or google search. Remote fobs can be had for low cost on eBay used or new.
Old Dec 4, 2020 | 11:37 AM
Prophecy99's Avatar
chipless keys? i thought we needed a chip? im confused
Old Dec 4, 2020 | 01:27 PM
TallTom's Avatar
He uses keys without chips to enter the car, not start it.
Old Dec 4, 2020 | 02:57 PM
J P D's Avatar
What a hassle - I bought a couple of transmitters for $8 each before they became hard to find.
Luckily I was given all the keys including valet when I got my Max.
Old Dec 4, 2020 | 10:50 PM
User1's Avatar
2KI30NYC
Nov 9, 2012 07:13 PM
Garf
Feb 27, 2009 07:13 AM
Reket
27
Feb 26, 2008 06:21 AM
eckounltd287
Jan 7, 2007 07:33 PM
stinger73
Nov 21, 2003 08:19 AM
