intermitten clutch pedal pressure loss
Old Oct 23, 2020 | 08:18 AM
uptownsamcv's Avatar
My car has had an issue for the longest time where it would lose clutch pressure than after a while it will go back to normal. last night was the worst case. the pedal went super soft and I had a real hard time going into 1st at stops, luckily I made it home ok. this morning I gave it a few pumps and I instantly had pressure. I drove for an hour this morning and it was fine.
Does anyone have any ideas?
Old Oct 23, 2020 | 10:16 AM
TallTom's Avatar
What does the fluid level look like?
Old Oct 23, 2020 | 11:01 AM
The fluid is always full, I have never had any issues with leaks or fluid loss. it happened after doing 30 minutes of driving after I finished installing my transmission.
instead of disconnecting the line like I usually do when removing the transmission I just removed the slave cylinder from the tranny this time to avoid having to bleed it.
I drove around this morning for an hour with no issue and I picked up some brake fluid. when I got home I removed the old fluid and refilled the master cylinder. I'll probably do a full flush and bleed later on today...
Old Oct 23, 2020 | 11:57 AM
TallTom's Avatar
When my clutch was replaced last year, they also had to replace the slave cylinder since it wasn't holding pressure. And they installed SS clutch lines while in there.
If the flush & bleed doesn't keep the pressure, I would look to swap the slave cylinder.
Old Oct 23, 2020 | 12:10 PM
it's an intermittent problem, right now it's fine but I'm sure at some point it will do it again.
Dbird
Sep 6, 2011 07:48 PM
wunfstmax
Jun 20, 2005 12:28 PM
96shogunmax
Apr 6, 2003 06:37 PM
Lushka16
Mar 26, 2003 05:16 PM
blackandwhite
Oct 27, 2001 06:11 AM
