Bad Cat Symptoms?
Old Nov 11, 2020 | 08:49 AM
ukmastermind's Avatar
Bad Cat Symptoms?
In the past month, I've been hearing a pretty loud crack/pop after I turn off the engine. I narrowed it down to the Front Cat making the noise every 1ish mins.
Is this a sign the cat is on it's way out?
-Mpg:21 (can't break 21mpg even w/90% Hwy on 91)
-Both Upstream 02 replaced recently
-Power: seems about the same.
Old Nov 11, 2020 | 10:43 AM
TallTom's Avatar
There is chance its breaking apart. They either break apart or clog and if it was clogged, you would notice a power issue.
If you narrowed it down to the precat, I would either replace it or take it out and gut it (and install a non-fouler on the downstream o2 sensor.
Old Nov 11, 2020 | 09:23 PM
Not sure I can gut it since I have a Smog Check coming up in 7 months. Wonder if I need to replace all the cats or just the precat up front? I know 02 sensors are replaced in pairs .
Old Nov 12, 2020 | 04:28 AM
Prophecy99's Avatar
if one is shot, the idea is the other is close behind or the same, same logic with the O2 sensors, you can gut and use a O2 extender or get a O2 sim (give or take $100 and sometimes hard to find, sometimes not)
or keep it simple and expensive and just replace.
if you hear this noise consistently maybe have a shop check it out instead of assuming precats too, ya never know
Old Nov 12, 2020 | 05:40 AM
uptownsamcv's Avatar
engine pinging, underhood heat, and rotten egg smell are usually associated with clogged cats.
PatKeo6373
Feb 21, 2011 10:14 PM
erty67
Sep 30, 2003 02:51 PM
kingrukus
Aug 27, 2003 01:23 PM
Nick97SE
Jun 8, 2003 09:32 AM
97GreenMax
Oct 2, 2001 03:49 PM
