I need help on changing fog light bulbs!!!
search, works
This is what i DID:
go to search in top right corner and type fog lights in 5th gen forum search. Read everything it shows ups. Thers like 15 threads. ANyway, read all of them, they are not redundant, Each one tells you a little something. start on the driver side also.
Roger
Roger
Ok, changeing the bulb is not hard, did U take the light out of the socket yet? If so, push the clip down and out and it lifts up, U can now take the bulb out. If U need help getting to the lights then U go under the car, On the left or right, U need to pop 1 plastic Button, and take out 2 phillip screws, Push back on the Plastic panal and pull down. U can now stick your hand inside and work with the fog assembley.
Look at this Site and see if it helps you out. http://www.his.com/~wc/maxima/ Paul I'm linking your site, hope U don't mind.
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
MikesChevelle
08-06-2015 11:36 AM
