Check Engine light Gen 5 (2000) stuck on
Old Jul 19, 2021 | 09:51 AM
Bevy's Avatar
code reader doesnt work. what are some of common issue for the light coming on ?
will it come on with bad injector or a bad coil ?
I ripped apart the stearing column and taped the chip key next to the tumbler so I could get a standard cut key to work which it works fine.
Can't imagine that has anything to do with it...! , the security has beed removed for a real long time and no problems with that being gone.
Old Jul 19, 2021 | 09:57 AM
TallTom's Avatar
You need a working code reader to troubleshoot.
Old Jul 19, 2021 | 11:17 AM
Bevy's Avatar
I Went to AutoZone and they said because the security was disabled the reader would not submit any information?
Old Jul 19, 2021 | 11:22 AM
Bevy's Avatar
Old Jul 19, 2021 | 01:37 PM
TallTom's Avatar
How was security disabled? A chipped key in the ignition (or next to it) is normal procedure when starting the car.
I would invest in a $20 code reader.
Old Jul 20, 2021 | 11:50 AM
RA030726's Avatar
I'm nutty for Nissans
They are wrong. I have done the same thing with the chip placed next to the ignition cylinder for years with no issues.
You might have a bad ECU. Open it and look for damage or burned components.
Old Jul 23, 2021 | 09:07 AM
Bevy's Avatar
bad code reader plug
tried 3 , seems the plug does not work !
Old Jul 23, 2021 | 09:09 AM
Bevy's Avatar
I have been driving it like that, with key taped near the tumbler... works just fine
Cubaknow
Oct 24, 2013 10:46 AM
hot_wax_tree
Feb 7, 2011 08:22 AM
Feldman
May 25, 2010 05:12 PM
dougb
Jun 9, 2009 07:44 AM
Mctwist77
Jan 14, 2008 07:08 PM
