2001 Not starting
Old Jul 28, 2021 | 12:28 AM
Zmaxima's Avatar
2001 Not starting
Hi all. I have an 01 Which is cranking but not starting. Secury light flashes when key is inserted. Does not flash when cranking. I replace the fuel pump not sure if it need to be replace. No spark at the plug. What could it be?
Old Jul 29, 2021 | 12:56 AM
maxiiiboy's Avatar
"Does not flash when cranking" - ok, but is the light ON or OFF? If ON, you have a NATS problem. If OFF, you problem is somewhere else. I would start by checking the fuses, and the ENG CONT1 fuse in particular. It's located in the engine compartment, in the fuse box next to the battery.
searcherrr
29
Feb 27, 2020 01:54 PM
jharper114
Sep 21, 2014 06:46 PM
Jonathan Braun
Jun 11, 2013 06:16 PM
caper
Dec 8, 2006 08:10 AM
