Noise From Front While Driving
Old Dec 26, 2021 | 08:27 PM
CRBWS6's Avatar
https://www.youtube.com/watch?v=WgJUaB_7dF0
Any ideas? Occurs constantly (straight, turning wheel, braking, in gear or neutral). Most notable around 30-40mph. Sounds like a mild intermittent brushing/rubbing sound that varies with speed of vehicle. Sounds like it's from the front left. Not sure if it was doing it prior, but I did just replace the lower control arms which involved removing the axle. Cannot hear with windows up.
Checks that have been done:
Brakes - pulled pads, lubed and re-assembled.
Tapped on rotors and no rocks were dis-lodged.
Dust shield is not bent.
Axle nut torque checked (217 #).
Confirmed that new LCA bolts torqued properly.
No bearing play.
Fender liner is not loose.
Tightened end link.
Not a clicking sound (i.e. CV joint).
Sounds normal when spin wheel while in the air.
Tested with different wheel/tire.
Old Dec 28, 2021 | 03:10 PM
User1's Avatar
Rotor
Old Apr 8, 2025 | 08:01 AM
Sleepyhawk's Avatar
Did you find the cause? I have a very similar issue.
Old Apr 8, 2025 | 05:23 PM
uptownsamcv's Avatar
what did you torque the axle nut to?
Old Apr 9, 2025 | 07:12 AM
Sleepyhawk's Avatar
I found the answer in another post here.
It was a wheel bearing.
The guy posted a video with the exact noise mine is making.
He then posted an update stating that the wheel bearing was the culprit.
EDIT: After spending $160 on faulty diagnosis and $80 on unneeded parts I changed the wheel bearing myself and fixed the issue.
Old Apr 9, 2025 | 09:35 AM
last time I had a wheel bearing failure was from over tightening the axle nut. the FSM says 188 - 245 ft-lbs but I stick with 160 ft lbs. too little torque and you'll have play and too much will overload the wheel bearing and it will wear prematurely.
Old Apr 12, 2025 | 07:56 PM
oughtsix's Avatar
I had the front wheel bearings on my 2003 replaced 3 times by the same shop before they figured out how to get it right. After the 3rd replacement within a 10K stretch the front bearings have been fine for about 30K now.
I really think Nissan cheaped out on bearing sizing in the Maxima... but I am used to taper roller bearings in trucks that last forever instead of itty bitty ball bearing wheel bearings.
odawg23
Jun 5, 2012 10:19 AM
silvermax2k2
Dec 17, 2006 05:37 PM
asta4
Sep 10, 2006 08:07 PM
talisman311
Mar 22, 2006 10:56 AM
Wheelie King
Apr 14, 2005 04:50 PM
