Threaded lug nut rear wheel
Old Apr 14, 2025 | 05:40 PM
Budge's Avatar
Hi all have a badly rounded off rear wheel nut tried all ways and different tools wondering can I just take the wheel off with the brake disc attached once I remove the calliper
Old Apr 14, 2025 | 09:48 PM
westdude's Avatar
thankfully never needed to try one, but there are such things as lug nut removal tools...
... but you may have tried that. I also imagine tire places have had to do that once in a while. taking the hub off w/o taking off the wheel first sounds too hard.
Old Apr 14, 2025 | 11:28 PM
oughtsix's Avatar
There are 2 caliper bolts to remove the caliper from the caliper bracket. Then there are 2 caliper bracket bolts that hold the caliper bracket to the suspension arm.
I do not believe you can remove the disc without removing the caliper bracket. You do not need to remove the caliper from the caliper bracket before removing the caliper bracket from the suspension arm to access the disc and remove it.
Old Apr 15, 2025 | 08:01 AM
slvr2KSE5's Avatar
forgetting about the wheel bearing/hub that is holding the entire assy onto the axle.
Old Apr 15, 2025 | 08:39 AM
westdude's Avatar
That
MaxFanatik
29
Aug 17, 2007 08:37 AM
96blackmaxSE
Sep 26, 2005 09:33 PM
mb1
May 7, 2004 10:35 AM
bosa1
Apr 6, 2004 11:39 AM
