Transmission fluid help ?
Old Apr 12, 2022 | 06:15 AM
01i30tback2life's Avatar
I changed my transmission fluid dropping the pan and changing the filter around 40,000 miles ago I'm looking to do it again I just forget I believe I used matic D last time this time around I have purchased Valvoline automatic transmission fluid full synthetic that is compatible with dexron 3 looking in the manual it clearly states to use Nissan matic d but dexron 3 may also be used ? If I mix 4 quarts of the valovine with the other 6 left in the tranny that is probably matic d will I have problems ... ? I can't remember what kind of ATF I used 40 k ago
Rgor
Last edited by 01i30tback2life; Apr 12, 2022 at 06:16 AM. Reason: Forgot to mention I will be only looking to remove transmission drain plug this time around
Old Apr 13, 2022 | 12:09 AM
Child_uv_KoRn's Avatar
Bad *** Newb
oem fluid is basically dexron 3. Virtually anything compatible works fine. I've use mobil 1, Syntec HM, Castrol import, and who knows what else.
Get it all out through the cooler return hose.
Old Apr 13, 2022 | 06:44 PM
Can I mix fluids ???
Old Apr 14, 2022 | 03:38 PM
Bad *** Newb
Yes. Hydraulic fluid is hydraulic fluid as long as it's the same stuff (obviously ATF) and within spec, which is viscosity in this case. Not any different than mixing engine oil.
Old Apr 14, 2022 | 07:01 PM
Ok last question can I get in trouble if it is synthetic oil I'm putting in and there is a synthetic blend or non synthetic inside the transmission ??? Thanks for your help man I wish I remember what I did 40k ago
Old Apr 14, 2022 | 10:38 PM
Bad *** Newb
No, you're fine.
regent1
May 11, 2012 07:28 PM
aminus21
Aug 29, 2004 04:17 PM
philly96maxima
May 18, 2003 07:26 AM
KDs96MAX
Apr 4, 2001 04:01 PM
OnTheRoad
Dec 1, 2000 03:26 PM
