LSD Options for 2002 - 2006 VQ Fwd V6 - Jannarelly Design-1
Old Jan 26, 2023 | 09:36 PM
Jannarelly Canada's Avatar
Hi Folks -
Very excited to be assembling a carbon bodied, mid engined VQ Jannarelly north of the border
Having a heck of a time finding an off-the-shelf high quality limited slip differential for track use and aggressive street
Any recommendations?
This VQ and transaxle assembly are likely euro market with manual gear box
Need something within 3 weeks to keep my build on schedule! Cheers !
Stephen
Old Jan 27, 2023 | 04:25 AM
uptownsamcv's Avatar
when I was looking, the best option was the helical LSD from the 2002 - 2006 Sentra SE-R Spec V. I went on www.car-parts.com and found a donor tranny for $350. most people change to the Spec V's closer gear ratios but I kept the stock Maxima 6 speed gearing. I've had it in my 02 6 speed Maxima for over a year and it works great. as you can see in the picture below, the Spec V trannys are selling pretty cheap in the salvage yards near me..
Old Jan 27, 2023 | 04:55 AM
Looks like the spec v was the four cylinder
will this lsd work in my six cylinder box ? I have 3.5L VQ
Old Jan 27, 2023 | 05:09 AM
yes, the LSD in the 2002 - 2006 Sentra SE-R Spec V shares the same part number with the factory LSD that came optional in the 3.5 6 speed Maxima's
Old Jan 27, 2023 | 07:07 AM
Very cool
my gearbox is a five speed though….
still work you think?
any aftermarket locking diff options out there that you know of?
Old Jan 27, 2023 | 09:04 AM
not sure, but here's a link to a thread you may want to check out since I see Canada in your user name...
https://maxima.org/forums/5th-genera...-come-lsd.html
Old Jan 27, 2023 | 08:53 PM
Really appreciate the guidance!
Mine is a 5 speed which doesn’t seem to add up
Likely euro origin
Where can I find the tranny part number? And cross reference to match a year and model of car for other tranny compatibility ?
cheers
Old Jan 27, 2023 | 08:58 PM
slvr2KSE5's Avatar
Likely euro origin
cheers
Manual? You'll be looking at 95-01 us cars. Don't know what's out there other than the garbage oem viscous lsd but the helical spec v option mentioned earlier won't work.
You should probably source a 6 speed.
Old Jan 27, 2023 | 09:07 PM
Yes manual
If there is a chart for part numbers for engines and trannys would be awesome
What year and model of 6 speeds would bolt up?
In 6 speed boxes what are the aftermarket options for proper lsd’s?
I think my best option is to open the tranny and measure the differential up and send to Quaiffe, Cusco etc
Old Jan 27, 2023 | 09:13 PM
slvr2KSE5's Avatar
Yes manual
02-06ish
Oem helical is great. Might as well be a quaife.
Old Jan 30, 2023 | 05:45 PM
Scooped a 2003 Sentra spec v 6 speed box locally
Should fit eh?
Old Jan 31, 2023 | 11:35 AM
slvr2KSE5's Avatar
Should fit eh?
You'll need a 6 speed vq bellhousing, get that and it'll fit
Old Jan 31, 2023 | 03:30 PM
What year and model did those come on?
Old Jan 31, 2023 | 05:01 PM
the 6 speed for the front wheel drive VQ35 was in the 02-06 Maxima and 05-06 Altima SE-R
Old Jan 31, 2023 | 06:06 PM
Your help is really appreciated !
As you suggested the bellhousings are different
But transmission side appears to be the same
Just found this however ! Love carpart.com !
2003
Transmission Assembly
Nissan Maxima 3.5L,6MT,FWD,5Y774
Supposedly it is a lsd model according to carpart search engine
You suggested this bellhousing would work
But maybe the lsd from the maxima is viscous not mechanical ?
would be nice to have a complete unit to bolt on !
Old Feb 1, 2023 | 04:47 AM
How is reverse engaged with the shifter in the car cabin on a 5 speed Nissan box vs a 6 speed?
My car has a customer billet shift **** and linkage - not sure that it has a up / down actuation that say a vw shifter has ….
Old Feb 1, 2023 | 01:58 PM
2003
if it's a 6 speed LSD model they are selling it will be a helical LSD...
Old Feb 1, 2023 | 02:38 PM
Perfect
If so, then why go down the path of the Sentra SER V spec for the transmission side only?
Old Feb 1, 2023 | 03:03 PM
slvr2KSE5's Avatar
Perfect
Cost and availability.
For me it was cheaper to buy the Sentra trans and swap the diff into my 6 speed than it was to find an LSD trans.
Old Feb 1, 2023 | 04:30 PM
280,000 km maxima box
vs 75,000 km on the Sentra box that I have now
would be nice to just bolt it up and go
but should likely rebuild the maxima one with that sort of mileage and track use
Old Feb 1, 2023 | 05:32 PM
when I got my Spec V H-LSD I paid $350 for the tranny and returned that tranny with the tranny minus diff to get my core charge back ($150). I kept the stock Maxima gearing in my tranny since I have no gear grinding issues.
Old Feb 12, 2023 | 08:38 PM
Finally got the box pulled apart !
This should be a 6 speed, close ratio box from a Sentra SER Spec V with LSD
Look correct ?
Old Feb 12, 2023 | 09:47 PM
nanotech's Avatar
@slvr2KSE5 when you swapped the diff, I assume you unbolted it from Spec-V ring gear and mated to the Maxima ring gear? I imagine the ring gears don't line up... but the diff bolts do? No special sauce between the diff and the ring gear?
Old Feb 13, 2023 | 12:07 PM
slvr2KSE5's Avatar
Correct. Ratio is different from the Maxima to Sentra. You can use the Sentra internals with the Maxima bell housing for a short geared trans.
Old Feb 13, 2023 | 02:17 PM
Have you noticed a lower top end with the 6 speed?
Is final drive ratio about the same between them?
No issues accessing reverse with the 5 speed shift **** and linkage in the interior ?
Old Feb 13, 2023 | 02:53 PM
slvr2KSE5's Avatar
My car isn't a swap. Factory 6 speed car so I can't answer any of those questions but I can say the shift linkage in a 5 speed Maxima will not work in any way with the 6 speed. 6 speed uses cables.
Old Apr 1, 2023 | 12:43 PM
philipw162's Avatar
[QUOTE=Jannarelly Canada;9251343]Perfect
Hey
I built one of these in the US, I have a lot of part number info etc. Let me know if I can help.
Old Apr 1, 2023 | 06:24 PM
PM sent Philip !
Old Apr 3, 2023 | 09:36 AM
@philipw162 sent you a pm. Please contact me for discussion on Jannarelly.
cheers !
Old May 28, 2024 | 01:25 AM
zip744's Avatar
Did you finish it Jannarelly?
cheers !
I was just wondering if you ever finished it
SpeedCrazie
Jun 18, 2006 09:08 PM
phenryiv1
Oct 19, 2002 02:16 PM
wolfmanjack210
Oct 6, 2001 05:15 AM
