01 VQ30DE-K bank 2 Pre-Cat gasket?
Old Feb 22, 2023 | 03:32 AM
Veewee's Avatar
Update:
Actually the outer ring around the catalyst material is gasket, it's like ring type crush gasket...
TL"DR
Anyone know that bank 2 pre-cat have gasket or not?
Mine look like this when I remove it, nothing fall out or extra... Thanks
Full story:
Today I had remove both pre-cat to replace the leaking steering rack, but I'm sure that pre-cat has been removed by workshop before judging by the nut is not even hand-tighen at all. After remove it I didn't notice any metal gasket or wire gasket at the manifold to pre-cat mating surface, is this normal? Or maybe I just overlooking something? Thanks
Old Feb 22, 2023 | 06:23 AM
slvr2KSE5's Avatar
No gasket
Old Feb 22, 2023 | 06:38 AM
Veewee's Avatar
No gasket
Alright, thank you very much
Old Feb 22, 2023 | 09:03 AM
RA030726's Avatar
I'm nutty for Nissans
It appears you are missing 20840-3Y110 and 20822-3Y100.
Old Feb 22, 2023 | 11:57 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Clean the flange and use copper RTV.
There's definitely a gasket stuck around the cat material. Mesh crush gasket, iirc. Slather it all in RTV and reinstall.
Old Feb 22, 2023 | 12:14 PM
schmellyfart's Avatar
jk I can't read
Old Feb 22, 2023 | 04:26 PM
slvr2KSE5's Avatar
You guys must have different cars. I just installed a set for a customer 2 weeks ago. No gasket.
Rear cat does have a crush ring
Old Feb 22, 2023 | 05:17 PM
RA030726's Avatar
I just went through replacing these. Its a crush ring gasket.
Do you have a part number?
Old Feb 23, 2023 | 10:55 PM
Negative ghostrider. I'm guilty of not looking at the photo closely. That would be the two part numbers you posted earlier.
Old Feb 24, 2023 | 10:34 AM
slvr2KSE5's Avatar
Again. No gasket for bank 2 but there is a gasket on bank 1
Old Feb 24, 2023 | 04:21 PM
RA030726's Avatar
I think you are looking at a 3.5.
Old Feb 24, 2023 | 05:58 PM
slvr2KSE5's Avatar
Lolol
yep. I'll check a Cali spec de-k tomorrow. Didn't even pay attention to the title. Just saw the pic and mind went right to 3.5
Called it. There is a ring on the Cali spec de-k.
I35GEEK
Mar 1, 2022 03:15 AM
NABU6
Apr 6, 2011 06:53 PM
!PrjctMax!
Aug 7, 2008 06:57 PM
jwmaxse
Apr 13, 2004 09:15 AM
karguy
Jan 23, 2003 11:36 AM
