New tranny solenoids
Old Apr 6, 2023 | 08:21 PM
Donkeypunch's Avatar
Hi.
My tranny has been basically downshifting and staying in low gear for years but only when it's super hot in the summer.
and even then i just pull over and turn the car off/on to reset the solenoids and it's fine.
Sometimes i just rev it outand it will up-shift then.
it's getting bad now so my question is do i need to take the valve body out to do this job.
or can i just drop the pan and bolt them in?
http://boredmder.com/FSMs/Nissan/Maxima/2003/AT.pdf
in the manual it says to take everything apart but it just looks like it's for inspection purposes
like check springs and ***** stuff like that.
thanks for looking.
Old Apr 22, 2023 | 04:42 AM
User1's Avatar
I had the same issue. Two sensors for RE4F04B.
One speed, one Turbine. Easily accessible by removing driver side vertical splash shield on the inside of the wheel arch. I replaced both of mine with OEM and never had a problem since. If I had to do it a second time, they're so easy to get to that I'd roll the dice with cheap ebay sensors.
https://www.ebay.com/itm/403742341922
Old Apr 24, 2023 | 10:50 AM
ya i tried the speed sensor, idk what the turbine sensor is, but it didn't work i think it made it worse so i put the oem one back in.
rock auto sent me the wrong solenoids so i took off the valve body and the things didn't fit.
total waste of time and money.
Old Apr 24, 2023 | 02:14 PM
i used 1 1/2 gal of oil btw to fill it back up
and a luckas thickener bottle that's like 80$ right there i almost want to
just get another car ya know.
we'll see how the lucas does but it does feel more solid the shifts idk.
Old Apr 25, 2023 | 06:24 AM
User1's Avatar
Pull codes.
Old Apr 25, 2023 | 08:29 PM
slvr2KSE5's Avatar
Drain that crap out and put proper fluid in there without any bottles of additives.
busterdawg22
Sep 21, 2006 06:46 AM
MaxGordon7
Sep 2, 2005 11:55 PM
tavarish
Sep 21, 2004 01:52 PM
wizard6161
Mar 24, 2001 10:31 AM
