Stumped with this issue
Old Apr 14, 2023 | 03:12 PM
Aidanperry1's Avatar
My car is old but sturdy, I’ve been having issues with it wanting to stall while driving, it’s a 6 speed and only happens every now and then it’ll stall in all gears and neutral. Any ideas? Thanks
Old Apr 14, 2023 | 04:50 PM
ajahearn's Avatar
Any chance the fuel filter is just that clogged? Or perhaps the fuel pump (one unit) is going? Any codes?
Old Apr 14, 2023 | 07:50 PM
chrome91's Avatar
When it stalls do you lose all power to the dash and all the dash lights etc completely die or do the dash lights and everything stay on like if the key was in ACC mode?
Old Apr 14, 2023 | 07:52 PM
one code keeps coming back related to the thermostat but that’s all the fuel filter would be a good idea
exactly like stalling all dash lights on
Old Apr 22, 2023 | 04:25 AM
User1's Avatar
Charging system.
Old May 25, 2023 | 02:56 PM
blkAEmax82's Avatar
Glory Glory Man United
Do any codes come up at all/ Check engine light?
Old May 26, 2023 | 08:07 AM
uptownsamcv's Avatar
I think the stalling problems went away on my 6 speed when I either changed my fuel pump and filter or changed my throttle body, upgraded to 75mm...
Old May 29, 2023 | 04:36 PM
nick's Avatar
Test/replace the MAF sensor, check the fuel pressure at the rail, and clean the engine grounds.
Old May 29, 2023 | 08:06 PM
freezer's Avatar
I'd echo Nick's response and add to check the wiring at the MAF closely too. I had a similar stalling issue which was the result of a worn out MAF pigtail. It wasn't bad enough to make the ECU throw a code.
Old May 30, 2023 | 12:40 PM
CRBWS6's Avatar
May also just need a throttle body cleaning. Mine was stalling at stop lights, cleaned it, did the idle re-learn process (painful) and problem solved.
IceY2K1
Dec 22, 2005 04:58 PM
