A/C Issues
Old May 22, 2023 | 10:07 AM
allg32's Avatar
A/C Issues
No A/c in a 2003 GLE with Manual A/C controls. Compressor turns on and off when I move the control to heat or air. Plenty of freon, checked with gauges, checked the blend air motor and it is working correctly. Any ideas on what else to look at?
A/C was working last year and just now got hot enough to turn it on.
Old May 22, 2023 | 04:43 PM
uptownsamcv's Avatar
what are your pressures looking like? general rule is double the temperature +50 on the high side. check the pressure with gauges hooked up and hood closed...
Old May 23, 2023 | 12:22 PM
allg32's Avatar
The outside temp that da was probably 80-85
Old May 23, 2023 | 12:50 PM
slvr2KSE5's Avatar
Plenty of refrigerant? How much? Recover the system and see what comes out
Old May 23, 2023 | 01:05 PM
if that's your pressure with the system running, I would start with a new expansion valve..
Old May 23, 2023 | 01:52 PM
slvr2KSE5's Avatar
I would too if that's the case.
Old May 23, 2023 | 02:15 PM
allg32's Avatar
Appreciate it guys, that is where I will start
Old May 23, 2023 | 02:23 PM
with the age of these cars, you should get new rubber lines and drier. I have an 02 and when I installed my new compressor last summer I noticed the low pressure line collapsed under vacuum. I highly recommend installing new lines and drier while your at it.
Old May 23, 2023 | 03:01 PM
allg32's Avatar
Will do!
subs1000w
Feb 10, 2023 06:39 PM
I35GEEK
Aug 9, 2022 07:31 PM
acw
Jan 5, 2015 04:18 PM
jettatom
Jul 6, 2014 01:25 PM
Lontar1
Dec 1, 2009 12:02 PM
