Cold Hesitation
Old Jan 7, 2024 | 02:12 PM
User1's Avatar
Cold Hesitation
After all I've been through with this car, I feel kinda retarded asking this question, but I have a hesitation right after a cold start and I don't know what it is. Only happens once in the day in the morning right after cold start and I put it in drive to leave. Put it in gear, step on the gas, it falls on it's face for a second, picks back up and runs fine the rest of the day. No codes. MAF is new/ish Hitachi, sensors are all good, CKP sensor is new, I'm kinda lost. It behaves like a cold electrical connection that isn't making contact until it warms up and expands, then it's fine.
It also seems to surge when I kick down a gear at speed. Like starving for fuel or something. Fuel pump is new/ish Walbro, no intake leaks/unmeasured intake air that I can see. My stuff is pretty clean. I've kept good care of it since the swap. 5k oil intervals, all kinds of regular maintenance, etc. Hood is often up, I haven't ignored this car.
Thanks all
Old Jan 8, 2024 | 06:36 AM
uptownsamcv's Avatar
what year car do you have?
Old Jan 8, 2024 | 08:09 AM
User1's Avatar
2003 with gen2 VQ swap
Old Jan 8, 2024 | 03:41 PM
when you did the swap did you hard wire the throttle body or use an adapter?
Old Jan 9, 2024 | 03:27 AM
User1's Avatar
Interesting you ask about the throttle body wiring. I swapped in the beginning of 2019 and used the Nisformance pigtail for the throttle body. It gave me a lot of grief and I was constantly having to clear tb codes on the side of the road to be able to drive again. I ditched the Nisformance pigtail and hard-wired the throttle body and never had a problem again. This cold hesitation is the first time I've had an issue since. I think you might be going in the right direction with this. I'll look at the wiring and see if there's anything to see. I soldered the connections and do decent, proper work, so I'll be a bit surprised if it's my wiring.
Old Jan 9, 2024 | 07:56 AM
what region do you live in?
have you tried throttle body cleaning?
a friend of mine has a 2018 civic and I recently had to do a throttle body cleaning on it. his throttle body was getting kinda laggy and a bit unresponsive. I had him hold the gas down as I sprayed carb cleaner into the valve cover breather tube that leads to the throttle body hose. he' isn't a car guy at all and was getting ready to trade it in thinking his transmission was going bad lol...
Old Jan 9, 2024 | 08:06 AM
User1's Avatar
I'm in Tampa. You can find my build threads in my history. I think I'll check tb connections and go from there. I'll keep you posted. I'm off Thursday. I'll be doing oil and filter then too.
getflushed
22
Feb 9, 2011 04:51 PM
gdal
28
Jan 28, 2011 03:18 PM
getflushed
Dec 21, 2010 08:51 PM
getflushed
Dec 14, 2010 05:11 PM
ChanMan96SE
Apr 20, 2006 09:30 AM
