Reintalling Strut spring assembly
Old Mar 7, 2024 | 06:36 AM
greekguy7's Avatar
Last night I removed the front left spring/strut assembly on my car. Is there any trick to reinstalling it, please? When I slide the top side with the 3 bolts in to the car with or without even putting the nuts in, I can’t seem to get the spindle/knuckle to clear and line up so I can get the bottom 2 bolts into the strut assembly. I tried and tried and tried. I don’t see why I need to remove the axle nut to get clearance I need
Old Mar 7, 2024 | 06:52 AM
RA030726's Avatar
I'm nutty for Nissans
You have both front wheels off the ground right?
Old Mar 7, 2024 | 07:01 AM
greekguy7's Avatar
Thank you for the reply!! NO.... I only have the one wheel off the ground. You think that will help?? Thanks again!
Old Mar 7, 2024 | 02:59 PM
RA030726's Avatar
You're fighting the sway bar with one wheel on the ground. Get the other side up and you'll have no problems.
Old Mar 8, 2024 | 04:56 AM
greekguy7's Avatar
update: I jacked the other side up so I have both wheels off the ground, turned the steering wheel to one side for more clearance and pushed down on the knuckle.... got it in easily. thanks!!
Max_01_SE
24
Mar 20, 2014 06:46 AM
Saddles
Jan 24, 2012 04:44 AM
rik3k
May 29, 2004 07:18 PM
Ladzio
Nov 18, 2003 01:28 PM
BobK
Oct 31, 2001 09:38 AM
