03 Ignition coil plug connector broken
Old Sep 4, 2024 | 10:16 PM
maxinout93's Avatar
Good day. My 03 i35 ignition coil plug came off basically its broken. Its on cylinder 2. I want to fix it correctly. Ive tried other plug ends but they dont seem to last long. Dont want to drive it like that because its misfiring and gonna kill the cat eventually. Anyone else have this issue or were successful at replacing this part?
Old Sep 4, 2024 | 10:56 PM
No local junkyards near you to acquire what you need?
Old Sep 5, 2024 | 09:10 AM
uptownsamcv's Avatar
when mine fell apart I ordered new ones online and wired them in.
Old Sep 7, 2024 | 07:57 AM
maxinout93's Avatar
they did i went to one yesterday. Kinda a rookie at electrical stuff.
Old Sep 7, 2024 | 08:03 AM
maxinout93's Avatar
ok great photo, but since the wires are thin, what did you use to join them togather? For a tight fit. I only have 1 coil wire connector that is broken. I went to swap wires on it yesterday by removing the connector and the green wire broke off. But i have a replacement connector and wire harness.
Old Sep 8, 2024 | 01:52 AM
I35GEEK's Avatar
The same thing happen to my 2003 I35. I ordered new connectors with wiring harnesses and replaced all 6 of them.
Since the coil packs are important electrical components, you want to rewire them properly. The best way is to solder the wires together. Then shrink wrapped them with wire protectors. They look like miniature straws and are applied using heat. Cut and replace one wire at a time do you don’t get them confused.
Old Sep 9, 2024 | 10:40 AM
I just twist twist the wires real good, cover them with heat shrink, and zip tie the ends real good so no moisture gets in. rewired them late 2021 and no issues. I even did the same with my cam sensors when I did my 7th gen swap. my soldering skills are nonexistent 😕
Old Sep 10, 2024 | 09:20 AM
maxinout93's Avatar
Thanks for the replies. Im finally glad to see where my problem is coming from all this time. But i bought this to join the wires togather.
Hope this works good.
Old Sep 10, 2024 | 09:30 AM
slvr2KSE5's Avatar
thats the worst thing you could have done. twisting and black tape would be a better option
Old Sep 10, 2024 | 04:20 PM
don't use that, it's for solid core wire
Old Sep 10, 2024 | 10:20 PM
maxinout93's Avatar
ok well im glad i didnt open it yet. I will take that back and get the tape and heat shrink wrap. I have a wire cutter/ splicer as well. But how do you apply heat to the heatshink wrap? I saw some in harbor freight though.
Old Sep 11, 2024 | 10:29 AM
I didn't heat mine, I just zip tied them tight on the ends.
Old Sep 11, 2024 | 11:32 AM
With a blow-dryer or a heat gun. It doesn't take much heat to activate the heat shrink tubing.
Old Sep 11, 2024 | 12:17 PM
maxinout93's Avatar
ok great this is what i have at this point.
Old Sep 22, 2024 | 05:45 PM
maxinout93's Avatar
so i got around to fixing my problem and the car is running fine, no misfire anymore, no running on 5 cylinders anymore lol.
Old Sep 23, 2024 | 09:20 AM
Great to hear. Have any pics of your handy work?
JDwyer2821
Sep 10, 2024 10:24 PM
StillenMax80x20
Sep 14, 2004 11:42 AM
bigx323
Jun 8, 2004 08:09 AM
Irish
May 27, 2004 07:40 PM
Maxnut
Oct 24, 2003 06:01 PM
