Moonroof reset for 2001
Old Mar 15, 2025 | 08:17 PM
FanaticMadMax's Avatar
Trying to scour the net on how to reset the moonroof on my 2001 since I can not find it anywhere all they say for the 2002 and up which is not the same step. mine will not close all the way I have to keep hit the button several times, even with tilt. Does anyone knows how to reset it since the car battery been disconnected for some time so I'm tryin got get it going again
Old Mar 17, 2025 | 10:05 AM
TallTom's Avatar
Instructions for 00-01 are here: https://maxima.org/forums/5th-genera...oof-motor.html
Old Mar 19, 2025 | 04:25 AM
I've already saw that post and tried that. I can't seem to get anything to go. As the poster, I read that you sent me the link, it only for 2002 models and newer since we don't have that "slider" switch on the 2001. The relay step, I tried that already and follow it but I'm surprise my owner manual does have no mention about the moon roof initialization or reset anywhere. I find it very disappointing that I have to figure out by a long shot.
Old Mar 19, 2025 | 08:09 AM
TallTom's Avatar
The thread also suggested disconnecting the battery and draining any residual energy by pressing the brake pedal and/or turning on the headlights. You will lose radio presets but it may be worth a shot.
Old Apr 10, 2025 | 08:13 AM
03_GLE's Avatar
I had a 2001 Maxima, and anytime the battery was disconnected I had to manually hold the button down while the moonroof fully opened. Then again holding it while it slid to close. Once this is performed once (or twice) the entirety of its functions should work properly. The tilt feature you can also perform the same action, and it should solve this issue for you. IF nothing works, chances are the battery grounds are dirty or not properly connected.
Old May 6, 2025 | 03:49 AM
5gMaxFL's Avatar
I feel you OP, the Sunroof is a pain and there isn't a lot of information about the 2000 / 2001 sunroof.
What happened to me was the sunroof motor would appear to be completely non-responsive after a while and "stuck" in position - it really seemed bricked.
Disconnecting the circuit breaker "E90" (under the dash) and disconnecting the battery didn't seem to resolve the issue in my case either.
But the fix above from 03_GLE seemed to work, I held must of held the tilt switch in the tilt/open for 30 seconds and released on a whim.
I don't believe there is any feedback from the system until you release and engage the switch again.
In my case, the sunroof was in a closed or near closed position (I had to disconnect the motor to manually slide it shut just before this incident).
I also can't fully close my sunroof (i.e. level with roof) using the sliders alone either and have to pulse the tilt button to be partially tilted up.
I tried the calibration in the FSM where you disconnect the motor and allow it to reach the full pinion travel then reconnect.
This resulted in the sun roof getting jammed - in the tilt up position. I'm throwing in the towel and will accept this non-ideal behavior where the
sunroof calibrated close position is not the actual closed position.
I suspect in my case that some parts (possibly bushings?) might be worn / loose or mis-adjusted over the years.
Personally, I'm not going to worry about it but have to be mindful about fully closing it.
Good luck!
BlackFlux
Jan 19, 2005 09:27 AM
NJ02maximaGLE
Jul 8, 2004 06:12 AM
raaizin
Oct 16, 2001 12:24 AM
