Squeaky Steering Wheel
Old Oct 13, 2025 | 12:48 PM
I35GEEK's Avatar
Whenever I turn my steering wheel from side to side there is an annoying squeaky noise. It sounds like it is coming from inside the steering column. I took a video of me turning the steeering wheel to give you an idea of the noise. Anyone else experienced the same problem?
File Type: mov
Old Oct 14, 2025 | 06:57 AM
uptownsamcv's Avatar
take the column cover off, look for a bearing, and lube it. that's all I can think off.
Old Oct 14, 2025 | 07:18 AM
I35GEEK's Avatar
thanks. I will give it a try. I put up
with this for a couple of years. Time to get it fix. The only other thing I could think
of is something to do with the clock spring mechanism
Old Oct 14, 2025 | 05:20 PM
only issue I ever had steering wheel related was the horn being stuck on. I disconnected it and it would still drain the battery so I ended up fixing it with rubber washers....
I35GEEK
May 10, 2021 09:09 PM
Country24
Apr 18, 2016 03:07 AM
michael454rs
Nov 29, 2011 06:02 PM
VigilanteMax
Nov 14, 2007 09:11 AM
