HELP: Y-Pipe Installed - Noise
Although, post install, the noise is pretty much exactly as expected when revving the engine across the power band, I am hearing a "bang" when I launch. There is a sound, clear, of something hitting something under there. I can rev from 500 to 6500 and nothing, but when I actually launch...that first second when the car lurches and you know the engine mounts are being stressed...that's when I hear a bump like something is hitting something. Any ideas?
I'm done working for tonight, but wanted to hear ideas of what I should look for tomorrow.
Re: HELP: Y-Pipe Installed - Noise
Re: Re: HELP: Y-Pipe Installed - Noise
Originally posted by emax95
Your engine is probably hitting your Y-Pipe. Either it's the Y-Pipes fault, the installer of the Y-pipe or your engine mounts are on there way out. I am going to go with my 1st nad 2nd choice
Don't worry. It's the Y-pipe rubbing on the cross-brace right by the cat. The one that's held on by like 10 bolts. Happens a lot, happened to me... I just took the cross-brace off, since it's only there in case your exhaust falls of at high speeds. Take the f**ker off and forget about it- or, if you're the paranoid type, go to a muffler shop and get a custom hangar for your y-pipe.
Oh... and... enjoy the gains! after 8K miles I still very much do!
T.
T.
Re: Re: Re: HELP: Y-Pipe Installed - Noise
Thoughts about why? The y-pipe itself seems to be a perfect fit. I installed it as close to perfect as I could get. One of the major problems was that the bracket which attaches to the rubber hanger from the stock pipe is not right. I had to push the pipe up VERY hard to get the pipe back on the rubber hanger. Almost pointless to hang it. I think one of my first changes will be "unhang" the pipe...any thoughts?
You have to lower the cross member or remove it completely - I recommend lowering it using washers (you'll need longer bolts as well). It does server a purpose insofar as structural rigidity is concerned. Also I wouldn't force the Y-pipe to align with the rubber hanger - the bolts attaching the manifolds to the block are only torqued to about 25 ft-lbs so you don't want to put any undue stress on these. Try haging the rubber hanger using only one of the fingers on the metal fork it's secured to - this will give you much more play to somehow attach it to the bracket. I had to "dremelize" this bracket and get creative to attach it to the rubber hanger. It does help dampen some of the noise and vibration as well so you want to attach it if at all possible. Which pipe do you have? If it's the Stillen - here's another dremel adjustment I had to make for a better fit. It's well worth the trouble though!
I love you guys...
This site is great...where else can you get that kind of response, so quickly. So, I guess I'm going to do some mid-day automobile work. What with the new engine mounts getting installed tomorrow, I want the launch to be clean first.
Re: Re: Re: Re: HELP: Y-Pipe Installed - Noise
Re: Re: Re: Re: Re: HELP: Y-Pipe Installed - Noise
Do you happen to recall what size the stock bolts are. I assume 14mm, but what length do you think I'll need (so I can run to the hardware store before getting underneath the car. Is it just the four bolts in your picture you are suggesting I lower?
Re: Re: Re: Re: Re: Re: HELP: Y-Pipe Installed - Noise
Originally posted by makeHerPurr
How long did the install take? Did you have help or were you able to finish this yourself?
I had the jack stands set at about 20", giving me almost three feet of clearance at the front lip of the fender (and that's with my body kit). That was enough room for me to work.
You've gotta lower all eight. I just took one of the bolts to the hardware store (actaully it was a store specializing only on nuts and bolts) and told them I needed the exact same thing just about 1/2" longer.
Re: I love you guys...
Thank You - donations can be sent to my e-mail address via paypal.
I'll check on the torque specs for the cross member bolts when I get home. I don't think these are that important to get torqued exactly to spec though as long as they are tight - probably 25 ft-lbs oughta do it as well.
Re: Re: I love you guys...
I'll buy you a beer if you're ever in town (and you're 21) though.
Thanks guys...once again!
I put seven flat washers under each bolt, between the beam and the underboady...plus a new flat washer and lock washer topside. It worked perfectly. No banging sound...and I look forward to the "bees in a can" sound disappearing shortly. My first drive after fixing the beam was in heavy rush hour, so still no serious test of the pipe. Tomorrow is the engine mounts, so the combination of intake on Saturday, y-pipe yesterday, and mounts tomorrow should make for a nice "new car" feel. I look forward to putting it to the test.
Thanks again.
Thanks again.
Re: Thanks guys...once again!
Thanks again.
Thanks again.
Re: Re: Thanks guys...once again!
Originally posted by MAX2000JP
The engine mounts are gonna make your idle harsh. The mounts will vibrate and make you car louder. Above idle you really cant tell they are there
Re: Re: Re: Thanks guys...once again!
Only a couple of people in the 5th gen forum have the Cattman mounts and I haven't heard anything that bad. Only a little shake in the steering wheel. No noise increase reported by them.
Re: Re: Re: Re: Thanks guys...once again!
My friend had them in his 4th Gen and they increased the sound at idle and shook his whole car. But then again his car has 80k on it.
What kind of Y-pipe are you using? You would think that the manufature could have perfected there pipe by now to fit the car properly. This is uneceptable IMO.
Small fraction? I’d say it’s approaching half of all Cattman Y owners. It seems like a smaller fraction because some people buy Stillen.
According to Brokenmotor, who helped me install my Y-Pipe, the issue is because Cattman made a hanger for their 4th gen Y-Pipes, but for some reason left it out on the 5th gen.
All that extra un-supported weight pulls down on the exhaust at the connections, i.e. at the cat and b-pipe. I would agree that letting it go for this long is unacceptable. By now, Cattman should have done something about this.
If I had it to do over again now, I’d go with Warpspeed’s when it comes out. But I’m still glad I didn’t give Stillen my money.
Anyway, moot point now. Enjoy your Y-pipe.
i have that banging noise since when i first got the y-pipe on... i had the little cross bar removed (the one that is held on with 2 bolts, 1 on each side) but that didnt get rid of the problem... the rubber hangers are a little to long and soft i think... did anyone come up with a solution to it without lowering the cross member bar? i really dont mind the noise so much but my friends do they think my car is falling apart lol
questions
Sorry for resurrecting this thread! But I have a couple of questions. I installed a cattman ypipe yesterday, after the install I noticed the same symptoms described in this thread. In fact after the install my pipe had my exhaust low to the point that it was rubbing with the cross member, so much so that I was getting hard vibrations (a creaking sound) along with the hard banging, when starting off. My pipe does not have hanger, so the first thing I did was to make one and see what happens. However, as many of you noticed with the flex after the hanger, it makes the hanger pretty much useless. I then lowered the cross member with washers and that got ride of the vibrations, however under hard jerking acceleration, I still get a banging noise. Unfortunately I found all this out after hours of troubleshooting the problem. Drove me nuts! My questions to you are.
-after 6 months how is everything holding up???
-did any of you hang your exhaust as well? Since I still get the knocking on the CM, I need to do this, but wanted to know how you went about it.
Re: questions
I've had mine for well over a year now (Stillen Y) and just checked it a few weeks ago. I wanted to make sure the flex section was OK. I dropped the cat, looked inside the pipe and the flex looked good as new!
You really need to get longer bolts and use more washers. The stock bolts aren't long enough and will not let you drop the cross member low enough (no need to drop anything else). It needs to be dropped at least 1/2" to 3/4". By the way, good job incorporating the rubber hanger in your set-up!
Re: questions
As far as how I hung the pipe...my Cattman pipe had a small bracket welded on to the top of the pipe close to the stock hanger location.
Re: Re: questions
cattmans
ok, i'm a new owner of the used cattman y-pipe. It bangs agains the cross member exactly as described in this thread. Is it possible that i can unscrew and put washers in myself or would i need to go to the shop and have them use the power gun to get them off?
thnx
thnx
Re: cattmans
thnx
thnx
MaxLife17
Jun 27, 2019 01:37 PM
