Another Check Engine Soon Light... :'-(
Old Feb 11, 2002 | 03:10 PM
AdamK's Avatar
Whats up guys, for the last 2 or 3 months I've had the dreaded Check Engine Soon Light. I mean honestly there is no problem, everything works in tip-top shape but it's ANNOYING. My car is stock. I just changed the oil (10w-30 mobil1) and filter + air filter. All I use is 93 octane gas and the cover is closed as tight as can be.
From time to time I see it go off only to turn on after about 50-100 miles. If I unplug my battery It'll go off and I'll go through one tank and on the middle of my second one it'll show up again. Someone PLASE HELP!!! thanks in adv. guys!!!
Old Feb 11, 2002 | 03:13 PM
MichaelAE's Avatar
Re: Another Check Engine Soon Light... :'-(
This might be a good time to go to the dealer and have them "check engine." Don't know, just a thought.
Old Feb 11, 2002 | 03:16 PM
AdamK's Avatar
Re: Re: Another Check Engine Soon Light... :'-(
Well this guy has a garage he said he'd hook it up to the comp for 20 or 50 bucks to decode it, but thats like 1 week worth of gas
Old Feb 11, 2002 | 03:23 PM
MichaelAE's Avatar
Re: Re: Re: Another Check Engine Soon Light... :'-(
How many miles do you have? You are still under warranty, right? Take it to the dealer for a checkup...tell them that the check engine light keeps coming on.
Old Feb 11, 2002 | 04:12 PM
ajahearn's Avatar
engine check light
When I got my 02 SE the sales guy told me that I must put the gas cap on absolutely tight to keep an air tight system. He said failing to do so would cause the check engine light to come on. Perhaps you have a slow leak in the cap or something. This is one possible explanation although certainly not the only answer. If you can't figure it out, I would agree with the other postings and let Nissan take a look. It may be an O2 sensor issue, etc. and that would be hard to diagnose otherwise.
Old Feb 12, 2002 | 03:50 AM
AdamK's Avatar
Re: engine check light
exactly 30k miles, u guys think nissan will diagnose for free?
Old Feb 12, 2002 | 05:37 AM
bimmersnomore's Avatar
Re: Re: engine check light
Do the 2k's have a 36 month 36,000 mile warranty? If so, then everything but maintenance should be covered. A check engine light is not maintenance.
Old Feb 12, 2002 | 05:56 AM
njmaxseltd's Avatar
Go back to the dealer!!!! Your still under warranty. You may need to have a program update done to your ECU.
Old Feb 12, 2002 | 09:38 AM
eortiz15's Avatar
It will be free only if they find a problem with the car.
If the problem is due to the gas cap, they will charge you.
I got charged $40 on my last "CEL" visit. Gas cap was loose
according to the dealer.
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
jfl330
Sep 4, 2015 01:44 PM
mikebla
Sep 3, 2015 05:37 PM
A32goldylocks
Sep 2, 2015 06:39 AM
